<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="971" width="815"> <operator activated="false" class="read_excel" compatibility="5.2.006" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30"> <parameter key="excel_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\pubs_500energy.xlsx"/> <parameter key="imported_cell_range" value="A1:F401"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="pub_id.true.integer.id"/> <parameter key="1" value="title.true.text.attribute"/> <parameter key="2" value="journal.true.text.attribute"/> <parameter key="3" value="keyword_plus.true.text.attribute"/> <parameter key="4" value="abstract.true.text.attribute"/> <parameter key="5" value="energy.true.binominal.label"/> </list> </operator> <operator activated="false" class="text:data_to_documents" compatibility="5.2.003" expanded="true" height="60" name="Data to Documents" width="90" x="45" y="120"> <list key="specify_weights"/> </operator> <operator activated="false" class="read_excel" compatibility="5.2.006" expanded="true" height="60" name="Read Excel (2)" width="90" x="45" y="255"> <parameter key="excel_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\pubs_500energy_withkeywords_2012-07-10.xlsx"/> <parameter key="imported_cell_range" value="A1:AB501"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="pub_id.true.integer.label"/> <parameter key="1" value="photovolt.true.binominal.attribute"/> <parameter key="2" value="solar energy.true.binominal.attribute"/> <parameter key="3" value="energy production.true.binominal.attribute"/> <parameter key="4" value="renewable energy.true.binominal.attribute"/> <parameter key="5" value="energy storage.true.binominal.attribute"/> <parameter key="6" value="fuel cell.true.binominal.attribute"/> <parameter key="7" value="batter.true.binominal.attribute"/> <parameter key="8" value="energy conversion technolog.true.binominal.attribute"/> <parameter key="9" value="solar cell.true.binominal.attribute"/> <parameter key="10" value="solar fuel.true.binominal.attribute"/> <parameter key="11" value="biofuel.true.binominal.attribute"/> <parameter key="12" value="alternative energy.true.binominal.attribute"/> <parameter key="13" value="sustainable energy.true.binominal.attribute"/> <parameter key="14" value="solar-energy.true.binominal.attribute"/> <parameter key="15" value="fuel-cell.true.binominal.attribute"/> <parameter key="16" value="hydrogen storage.true.binominal.attribute"/> <parameter key="17" value="artificial photosynthesis.true.binominal.attribute"/> <parameter key="18" value="h2 storage.true.binominal.attribute"/> <parameter key="19" value="energy application.true.binominal.attribute"/> <parameter key="20" value="power generation.true.binominal.attribute"/> <parameter key="21" value="solar hydrogen.true.binominal.attribute"/> <parameter key="22" value="biodiesel.true.binominal.attribute"/> <parameter key="23" value="energy generation.true.binominal.attribute"/> <parameter key="24" value="fuel.true.binominal.attribute"/> <parameter key="25" value="light harvesting.true.binominal.attribute"/> <parameter key="26" value="light-harvesting.true.binominal.attribute"/> <parameter key="27" value="keyword energy.true.binominal.attribute"/> </list> </operator> <operator activated="false" class="set_role" compatibility="5.2.006" expanded="true" height="76" name="Set Role (3)" width="90" x="121" y="322"> <parameter key="name" value="pub_id"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="false" class="text:process_documents" compatibility="5.2.003" expanded="true" height="94" name="Process Documents" width="90" x="179" y="30"> <parameter key="prune_method" value="percentual"/> <parameter key="prunde_below_percent" value="1.0"/> <parameter key="prune_above_percent" value="70.0"/> <parameter key="prune_below_absolute" value="2"/> <parameter key="prune_above_absolute" value="888"/> <process expanded="true" height="422" width="634"> <operator activated="false" class="text:tokenize" compatibility="5.2.003" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/> <operator activated="false" class="text:transform_cases" compatibility="5.2.003" expanded="true" height="60" name="Transform Cases" width="90" x="70" y="150"/> <operator activated="false" class="text:filter_stopwords_english" compatibility="5.2.003" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="102" y="226"/> <operator activated="false" class="text:filter_by_length" compatibility="5.2.003" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="232" y="224"> <parameter key="min_chars" value="2"/> <parameter key="max_chars" value="888"/> </operator> <operator activated="false" class="text:stem_snowball" compatibility="5.2.003" expanded="true" height="60" name="Stem (Snowball)" width="90" x="372" y="189"/> <operator activated="false" class="text:generate_n_grams_terms" compatibility="5.2.003" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="501" y="158"> <parameter key="max_length" value="3"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Snowball)" to_port="document"/> <connect from_op="Stem (Snowball)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/> <connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="false" class="write" compatibility="5.2.006" expanded="true" height="60" name="Write" width="90" x="179" y="165"> <parameter key="object_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\wordlist_500Energy"/> </operator> <operator activated="false" class="set_role" compatibility="5.2.006" expanded="true" height="76" name="Set Role (2)" width="90" x="313" y="30"> <parameter key="name" value="pub_id"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="false" class="join" compatibility="5.2.006" expanded="true" height="76" name="Join" width="90" x="246" y="300"> <list key="key_attributes"/> </operator> <operator activated="false" class="set_role" compatibility="5.2.006" expanded="true" height="76" name="Set Role" width="90" x="380" y="300"> <parameter key="name" value="energy"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="false" class="generate_weight_stratification" compatibility="5.2.006" expanded="true" height="76" name="Generate Weight (Stratification)" width="90" x="447" y="30"/> <operator activated="false" class="x_validation" compatibility="5.2.006" expanded="true" height="112" name="Validation" width="90" x="514" y="165"> <process expanded="true" height="422" width="292"> <operator activated="false" class="naive_bayes" compatibility="5.2.006" expanded="true" height="76" name="Naive Bayes" width="90" x="84" y="26"/> <connect from_port="training" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="422" width="292"> <operator activated="false" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="false" class="performance_binominal_classification" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="false" class="write_model" compatibility="5.2.006" expanded="true" height="60" name="Write Model" width="90" x="581" y="30"> <parameter key="model_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\model_500Energy_NaiveBayes"/> </operator> <connect from_op="Read Excel" from_port="output" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Read Excel (2)" from_port="output" to_op="Set Role (3)" to_port="example set input"/> <connect from_op="Set Role (3)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Process Documents" from_port="example set" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Process Documents" from_port="word list" to_op="Write" to_port="object"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Generate Weight (Stratification)" to_port="example set input"/> <connect from_op="Generate Weight (Stratification)" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_op="Write Model" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="971" width="815"> <operator activated="true" class="read_model" compatibility="5.2.006" expanded="true" height="60" name="Read Model" width="90" x="514" y="435"> <parameter key="model_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\model_500Energy_NaiveBayes"/> </operator> <operator activated="true" class="read_excel" compatibility="5.2.006" expanded="true" height="60" name="Read Excel (3)" width="90" x="12" y="467"> <parameter key="excel_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\cat100new_2012-07-11.xlsx"/> <parameter key="imported_cell_range" value="A1:E101"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="pub_id.true.integer.label"/> <parameter key="1" value="title.true.text.attribute"/> <parameter key="2" value="journal.true.text.attribute"/> <parameter key="3" value="keyword_plus.true.text.attribute"/> <parameter key="4" value="abstract.true.text.attribute"/> </list> </operator> <operator activated="true" class="text:data_to_documents" compatibility="5.2.003" expanded="true" height="60" name="Data to Documents (2)" width="90" x="112" y="525"> <list key="specify_weights"/> </operator> <operator activated="true" class="read" compatibility="5.2.006" expanded="true" height="60" name="Read" width="90" x="112" y="435"> <parameter key="object_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\wordlist_500Energy"/> <parameter key="io_object" value="WordList"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.2.003" expanded="true" height="94" name="Process Documents (2)" width="90" x="246" y="525"> <parameter key="prune_method" value="percentual"/> <parameter key="prunde_below_percent" value="1.0"/> <parameter key="prune_above_percent" value="70.0"/> <parameter key="prune_below_absolute" value="2"/> <parameter key="prune_above_absolute" value="888"/> <process expanded="true" height="404" width="643"> <operator activated="true" class="text:tokenize" compatibility="5.2.003" expanded="true" height="60" name="Tokenize (2)" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.2.003" expanded="true" height="60" name="Transform Cases (2)" width="90" x="180" y="30"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.003" expanded="true" height="60" name="Filter Stopwords (2)" width="90" x="315" y="30"/> <operator activated="true" class="text:filter_by_length" compatibility="5.2.003" expanded="true" height="60" name="Filter Tokens (2)" width="90" x="450" y="30"> <parameter key="min_chars" value="2"/> <parameter key="max_chars" value="888"/> </operator> <operator activated="true" class="text:stem_snowball" compatibility="5.2.003" expanded="true" height="60" name="Stem (2)" width="90" x="380" y="165"/> <operator activated="true" class="text:generate_n_grams_terms" compatibility="5.2.003" expanded="true" height="60" name="Generate n-Grams (2)" width="90" x="447" y="255"> <parameter key="max_length" value="3"/> </operator> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/> <connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/> <connect from_op="Filter Stopwords (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/> <connect from_op="Filter Tokens (2)" from_port="document" to_op="Stem (2)" to_port="document"/> <connect from_op="Stem (2)" from_port="document" to_op="Generate n-Grams (2)" to_port="document"/> <connect from_op="Generate n-Grams (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="set_role" compatibility="5.2.006" expanded="true" height="76" name="Set Role (4)" width="90" x="380" y="570"> <parameter key="name" value="pub_id"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="read_excel" compatibility="5.2.006" expanded="true" height="60" name="Read Excel (4)" width="90" x="43" y="660"> <parameter key="excel_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\cat100new_withkeywords_2012-07-11.xlsx"/> <parameter key="imported_cell_range" value="A1:AB101"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="pub_id.true.integer.id"/> <parameter key="1" value="photovolt.true.binominal.attribute"/> <parameter key="2" value="solar energy.true.binominal.attribute"/> <parameter key="3" value="energy production.true.binominal.attribute"/> <parameter key="4" value="renewable energy.true.binominal.attribute"/> <parameter key="5" value="energy storage.true.binominal.attribute"/> <parameter key="6" value="fuel cell.true.binominal.attribute"/> <parameter key="7" value="batter.true.binominal.attribute"/> <parameter key="8" value="energy conversion technolog.true.binominal.attribute"/> <parameter key="9" value="solar cell.true.binominal.attribute"/> <parameter key="10" value="solar fuel.true.binominal.attribute"/> <parameter key="11" value="biofuel.true.binominal.attribute"/> <parameter key="12" value="alternative energy.true.binominal.attribute"/> <parameter key="13" value="sustainable energy.true.binominal.attribute"/> <parameter key="14" value="solar-energy.true.binominal.attribute"/> <parameter key="15" value="fuel-cell.true.binominal.attribute"/> <parameter key="16" value="hydrogen storage.true.binominal.attribute"/> <parameter key="17" value="artificial photosynthesis.true.binominal.attribute"/> <parameter key="18" value="h2 storage.true.binominal.attribute"/> <parameter key="19" value="energy application.true.binominal.attribute"/> <parameter key="20" value="power generation.true.binominal.attribute"/> <parameter key="21" value="solar hydrogen.true.binominal.attribute"/> <parameter key="22" value="biodiesel.true.binominal.attribute"/> <parameter key="23" value="energy generation.true.binominal.attribute"/> <parameter key="24" value="fuel.true.binominal.attribute"/> <parameter key="25" value="light harvesting.true.binominal.attribute"/> <parameter key="26" value="light-harvesting.true.binominal.attribute"/> <parameter key="27" value="keyword energy.true.binominal.attribute"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.2.006" expanded="true" height="76" name="Set Role (5)" width="90" x="178" y="660"> <parameter key="name" value="pub_id"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="join" compatibility="5.2.006" expanded="true" height="76" name="Join (2)" width="90" x="447" y="705"> <list key="key_attributes"/> </operator> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model (2)" width="90" x="648" y="525"> <list key="application_parameters"/> </operator> <connect from_op="Read Model" from_port="output" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Read Excel (3)" from_port="output" to_op="Data to Documents (2)" to_port="example set"/> <connect from_op="Data to Documents (2)" from_port="documents" to_op="Process Documents (2)" to_port="documents 1"/> <connect from_op="Read" from_port="output" to_op="Process Documents (2)" to_port="word list"/> <connect from_op="Process Documents (2)" from_port="example set" to_op="Set Role (4)" to_port="example set input"/> <connect from_op="Set Role (4)" from_port="example set output" to_op="Join (2)" to_port="left"/> <connect from_op="Read Excel (4)" from_port="output" to_op="Set Role (5)" to_port="example set input"/> <connect from_op="Set Role (5)" from_port="example set output" to_op="Join (2)" to_port="right"/> <connect from_op="Join (2)" from_port="join" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_port="result 1"/> <connect from_op="Apply Model (2)" from_port="model" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="971" width="815"> <operator activated="true" class="read_excel" compatibility="5.2.006" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30"> <parameter key="excel_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\pubs_500energy.xlsx"/> <parameter key="imported_cell_range" value="A1:F501"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="pub_id.true.integer.id"/> <parameter key="1" value="title.true.text.attribute"/> <parameter key="2" value="journal.true.text.attribute"/> <parameter key="3" value="keyword_plus.true.text.attribute"/> <parameter key="4" value="abstract.true.text.attribute"/> <parameter key="5" value="energy.true.binominal.label"/> </list> </operator> <operator activated="true" class="text:data_to_documents" compatibility="5.2.003" expanded="true" height="60" name="Data to Documents" width="90" x="45" y="120"> <list key="specify_weights"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.2.003" expanded="true" height="94" name="Process Documents" width="90" x="179" y="30"> <parameter key="prune_method" value="percentual"/> <parameter key="prunde_below_percent" value="1.0"/> <parameter key="prune_above_percent" value="70.0"/> <parameter key="prune_below_absolute" value="2"/> <parameter key="prune_above_absolute" value="888"/> <process expanded="true" height="422" width="634"> <operator activated="true" class="text:tokenize" compatibility="5.2.003" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.2.003" expanded="true" height="60" name="Transform Cases" width="90" x="70" y="150"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.003" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="102" y="226"/> <operator activated="true" class="text:filter_by_length" compatibility="5.2.003" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="232" y="224"> <parameter key="min_chars" value="2"/> <parameter key="max_chars" value="888"/> </operator> <operator activated="true" class="text:stem_snowball" compatibility="5.2.003" expanded="true" height="60" name="Stem (Snowball)" width="90" x="372" y="189"/> <operator activated="true" class="text:generate_n_grams_terms" compatibility="5.2.003" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="501" y="158"> <parameter key="max_length" value="3"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Snowball)" to_port="document"/> <connect from_op="Stem (Snowball)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/> <connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="write" compatibility="5.2.006" expanded="true" height="60" name="Write" width="90" x="179" y="165"> <parameter key="object_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\wordlist_500Energy"/> </operator> <operator activated="true" class="set_role" compatibility="5.2.006" expanded="true" height="76" name="Set Role" width="90" x="313" y="75"> <parameter key="name" value="energy"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_weight_stratification" compatibility="5.2.006" expanded="true" height="76" name="Generate Weight (Stratification)" width="90" x="447" y="30"/> <operator activated="true" class="x_validation" compatibility="5.2.006" expanded="true" height="112" name="Validation" width="90" x="514" y="165"> <process expanded="true" height="422" width="292"> <operator activated="true" class="naive_bayes" compatibility="5.2.006" expanded="true" height="76" name="Naive Bayes" width="90" x="64" y="36"/> <connect from_port="training" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="422" width="292"> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="write_model" compatibility="5.2.006" expanded="true" height="60" name="Write Model" width="90" x="581" y="30"> <parameter key="model_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\model_500Energy_NaiveBayesNoKW"/> </operator> <connect from_op="Read Excel" from_port="output" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_op="Set Role" to_port="example set input"/> <connect from_op="Process Documents" from_port="word list" to_op="Write" to_port="object"/> <connect from_op="Set Role" from_port="example set output" to_op="Generate Weight (Stratification)" to_port="example set input"/> <connect from_op="Generate Weight (Stratification)" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_op="Write Model" to_port="input"/> <connect from_op="Validation" from_port="training" to_port="result 1"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="971" width="815"> <operator activated="true" class="read_model" compatibility="5.2.006" expanded="true" height="60" name="Read Model" width="90" x="514" y="435"> <parameter key="model_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\model_500Energy_NaiveBayesNoKW"/> </operator> <operator activated="true" class="read_excel" compatibility="5.2.006" expanded="true" height="60" name="Read Excel (3)" width="90" x="12" y="467"> <parameter key="excel_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\cat100new_2012-07-11.xlsx"/> <parameter key="imported_cell_range" value="A1:E101"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="pub_id.true.integer.label"/> <parameter key="1" value="title.true.text.attribute"/> <parameter key="2" value="journal.true.text.attribute"/> <parameter key="3" value="keyword_plus.true.text.attribute"/> <parameter key="4" value="abstract.true.text.attribute"/> </list> </operator> <operator activated="true" class="text:data_to_documents" compatibility="5.2.003" expanded="true" height="60" name="Data to Documents (2)" width="90" x="112" y="525"> <list key="specify_weights"/> </operator> <operator activated="true" class="read" compatibility="5.2.006" expanded="true" height="60" name="Read" width="90" x="112" y="435"> <parameter key="object_file" value="C:\Users\litovitz\Documents\dissertation\rapidminer\wordlist_500Energy"/> <parameter key="io_object" value="WordList"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.2.003" expanded="true" height="94" name="Process Documents (2)" width="90" x="246" y="525"> <parameter key="prune_method" value="percentual"/> <parameter key="prunde_below_percent" value="1.0"/> <parameter key="prune_above_percent" value="70.0"/> <parameter key="prune_below_absolute" value="2"/> <parameter key="prune_above_absolute" value="888"/> <process expanded="true" height="404" width="643"> <operator activated="true" class="text:tokenize" compatibility="5.2.003" expanded="true" height="60" name="Tokenize (2)" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.2.003" expanded="true" height="60" name="Transform Cases (2)" width="90" x="180" y="30"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.003" expanded="true" height="60" name="Filter Stopwords (2)" width="90" x="315" y="30"/> <operator activated="true" class="text:filter_by_length" compatibility="5.2.003" expanded="true" height="60" name="Filter Tokens (2)" width="90" x="450" y="30"> <parameter key="min_chars" value="2"/> <parameter key="max_chars" value="888"/> </operator> <operator activated="true" class="text:stem_snowball" compatibility="5.2.003" expanded="true" height="60" name="Stem (2)" width="90" x="380" y="165"/> <operator activated="true" class="text:generate_n_grams_terms" compatibility="5.2.003" expanded="true" height="60" name="Generate n-Grams (2)" width="90" x="447" y="255"> <parameter key="max_length" value="3"/> </operator> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/> <connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/> <connect from_op="Filter Stopwords (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/> <connect from_op="Filter Tokens (2)" from_port="document" to_op="Stem (2)" to_port="document"/> <connect from_op="Stem (2)" from_port="document" to_op="Generate n-Grams (2)" to_port="document"/> <connect from_op="Generate n-Grams (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model (2)" width="90" x="648" y="525"> <list key="application_parameters"/> </operator> <connect from_op="Read Model" from_port="output" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Read Excel (3)" from_port="output" to_op="Data to Documents (2)" to_port="example set"/> <connect from_op="Data to Documents (2)" from_port="documents" to_op="Process Documents (2)" to_port="documents 1"/> <connect from_op="Read" from_port="output" to_op="Process Documents (2)" to_port="word list"/> <connect from_op="Process Documents (2)" from_port="example set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_port="result 1"/> <connect from_op="Apply Model (2)" from_port="model" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
