<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="501" width="770"> <operator activated="true" class="generate_data" compatibility="5.2.006" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"> <parameter key="target_function" value="multi classification"/> </operator> <operator activated="true" class="generate_data" compatibility="5.2.006" expanded="true" height="60" name="Generate Data (2)" width="90" x="45" y="165"> <parameter key="target_function" value="multi classification"/> </operator> <operator activated="true" class="generate_data" compatibility="5.2.006" expanded="true" height="60" name="Generate Data (3)" width="90" x="45" y="255"> <parameter key="target_function" value="multi classification"/> </operator> <operator activated="true" class="generate_data" compatibility="5.2.006" expanded="true" height="60" name="Generate Data (4)" width="90" x="45" y="345"> <parameter key="target_function" value="multi classification"/> </operator> <operator activated="true" class="collect" compatibility="5.2.006" expanded="true" height="130" name="Collect" width="90" x="179" y="75"/> <operator activated="true" class="loop_collection" compatibility="5.2.006" expanded="true" height="76" name="Loop Collection" width="90" x="313" y="75"> <process expanded="true" height="501" width="614"> <operator activated="true" class="naive_bayes" compatibility="5.2.006" expanded="true" height="76" name="Naive Bayes" width="90" x="45" y="30"/> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="180" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="313" y="30"/> <operator activated="true" class="log" compatibility="5.2.006" expanded="true" height="76" name="Log" width="90" x="447" y="30"> <list key="log"> <parameter key="performance" value="operator.Performance.value.performance"/> </list> </operator> <connect from_port="single" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Naive Bayes" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" breakpoints="after" class="log_to_data" compatibility="5.2.006" expanded="true" height="94" name="Log to Data" width="90" x="447" y="75"> <parameter key="log_name" value="Log"/> </operator> <operator activated="true" class="write_excel" compatibility="5.2.006" expanded="true" height="76" name="Write Excel" width="90" x="581" y="75"> <parameter key="excel_file" value="tmp.xls"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Collect" to_port="input 1"/> <connect from_op="Generate Data (2)" from_port="output" to_op="Collect" to_port="input 2"/> <connect from_op="Generate Data (3)" from_port="output" to_op="Collect" to_port="input 3"/> <connect from_op="Generate Data (4)" from_port="output" to_op="Collect" to_port="input 4"/> <connect from_op="Collect" from_port="collection" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_op="Write Excel" to_port="input"/> <connect from_op="Write Excel" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
