<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="296" width="681"> <operator activated="true" class="generate_data" compatibility="5.2.006" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"> <parameter key="target_function" value="random classification"/> </operator> <operator activated="true" class="naive_bayes" compatibility="5.2.006" expanded="true" height="76" name="Naive Bayes" width="90" x="179" y="75"/> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="313" y="75"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="5.2.006" expanded="true" height="76" name="Performance (2)" width="90" x="447" y="75"/> <operator activated="true" class="combine_performances" compatibility="5.2.006" expanded="true" height="60" name="Performance" width="90" x="581" y="75"> <list key="criteria_weights"> <parameter key="recall" value="0.8"/> <parameter key="precision" value="0.2"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Naive Bayes" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_op="Performance" to_port="performance"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="595" width="815"> <operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="75" y="77"> <parameter key="repository_entry" value="../../dataset/10530_213_data"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.2.000" expanded="true" height="94" name="Replace Missing Values" width="90" x="313" y="75"> <list key="columns"/> </operator> <operator activated="true" class="normalize" compatibility="5.2.006" expanded="true" height="94" name="Normalize" width="90" x="45" y="345"/> <operator activated="true" class="free_memory" compatibility="5.2.006" expanded="true" height="76" name="Free Memory" width="90" x="179" y="480"/> <operator activated="true" class="remap_binominals" compatibility="5.2.006" expanded="true" height="76" name="Remap Binominals" width="90" x="380" y="390"> <parameter key="include_special_attributes" value="true"/> <parameter key="negative_value" value="inactive"/> <parameter key="positive_value" value="active"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.2.006" expanded="true" height="112" name="Optimize Parameters (Grid)" width="90" x="715" y="300"> <list key="parameters"> <parameter key="SVM.C" value="5,2,3,4,10,40,1"/> </list> <process expanded="true" height="540" width="471"> <operator activated="true" class="x_validation" compatibility="5.2.006" expanded="true" height="112" name="Validation" width="90" x="112" y="120"> <process expanded="true" height="558" width="219"> <operator activated="true" class="support_vector_machine" compatibility="5.2.006" expanded="true" height="112" name="SVM" width="90" x="45" y="30"> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="0.0010"/> <parameter key="C" value="1"/> <parameter key="convergence_epsilon" value="0.0010"/> <parameter key="L_neg" value="5000.0"/> <parameter key="balance_cost" value="true"/> </operator> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="701" width="279"> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="179" y="435"> <parameter key="main_criterion" value="sensitivity"/> <parameter key="accuracy" value="false"/> <parameter key="sensitivity" value="true"/> <parameter key="specificity" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.2.006" expanded="true" height="76" name="Log" width="90" x="313" y="255"> <parameter key="filename" value="/project/itdd/zhangx2/rapidminer_project/logfiles/log_Lpostive"/> <list key="log"> <parameter key="C" value="operator.SVM.parameter.C"/> <parameter key="gamma" value="operator.SVM.parameter.kernel_gamma"/> <parameter key="performance" value="operator.Performance.value.performance"/> </list> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Free Memory" to_port="through 1"/> <connect from_op="Free Memory" from_port="through 1" to_op="Remap Binominals" to_port="example set input"/> <connect from_op="Remap Binominals" from_port="example set output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_port="result 2"/> <connect from_op="Optimize Parameters (Grid)" from_port="result 1" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
awchisholm wrote:HelloThe "Extract Performance" operator may helpAt the risk of shameless self promotion here is a process that uses it.http://rapidminernotes.blogspot.co.uk/search/label/ClusterValidityregardsAndrew
xiazhang3 wrote:The issue with "combine performances" is that the resulting output would not contain the "performanceVector", "parameterVector", and "kernel model (SVM). Is there any way to show them up in the "results" window or store them as a file somehow after the optimization process?
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="296" width="949"> <operator activated="true" class="generate_data" compatibility="5.2.006" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"> <parameter key="target_function" value="random classification"/> </operator> <operator activated="true" class="naive_bayes" compatibility="5.2.006" expanded="true" height="76" name="Naive Bayes" width="90" x="179" y="75"/> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="313" y="75"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="5.2.006" expanded="true" height="76" name="Performance (2)" width="90" x="447" y="75"/> <operator activated="true" class="multiply" compatibility="5.2.006" expanded="true" height="94" name="Multiply" width="90" x="581" y="120"/> <operator activated="true" class="combine_performances" compatibility="5.2.006" expanded="true" height="60" name="Performance" width="90" x="715" y="30"> <list key="criteria_weights"> <parameter key="recall" value="0.8"/> <parameter key="precision" value="0.2"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Naive Bayes" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Performance" to_port="performance"/> <connect from_op="Multiply" from_port="output 2" to_port="result 2"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
Marius wrote:Combine performances does not output the confusion matrix. You have to connect the output of the standard Performance operator to the process output, too, e.g. with a Multiply. Please have a look at the attached process.Best, Marius
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="595" width="815"> <operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="75" y="77"> <parameter key="repository_entry" value="../../dataset/10530_213_data"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.2.000" expanded="true" height="94" name="Replace Missing Values" width="90" x="313" y="75"> <list key="columns"/> </operator> <operator activated="true" class="normalize" compatibility="5.2.006" expanded="true" height="94" name="Normalize" width="90" x="45" y="345"/> <operator activated="true" class="free_memory" compatibility="5.2.006" expanded="true" height="76" name="Free Memory" width="90" x="179" y="480"/> <operator activated="true" class="remap_binominals" compatibility="5.2.006" expanded="true" height="76" name="Remap Binominals" width="90" x="380" y="390"> <parameter key="include_special_attributes" value="true"/> <parameter key="negative_value" value="inactive"/> <parameter key="positive_value" value="active"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.2.006" expanded="true" height="112" name="Optimize Parameters (Grid)" width="90" x="715" y="300"> <list key="parameters"> <parameter key="SVM.C" value="5,1"/> </list> <process expanded="true" height="540" width="471"> <operator activated="true" class="x_validation" compatibility="5.2.006" expanded="true" height="112" name="Validation" width="90" x="112" y="120"> <process expanded="true" height="558" width="219"> <operator activated="true" class="support_vector_machine" compatibility="5.2.006" expanded="true" height="112" name="SVM" width="90" x="45" y="30"> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="0.0010"/> <parameter key="C" value="5"/> <parameter key="convergence_epsilon" value="0.0010"/> <parameter key="L_neg" value="5000.0"/> <parameter key="balance_cost" value="true"/> </operator> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="558" width="232"> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="45" y="210"> <parameter key="main_criterion" value="sensitivity"/> <parameter key="accuracy" value="false"/> <parameter key="sensitivity" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.2.006" expanded="true" height="76" name="Log" width="90" x="313" y="255"> <parameter key="filename" value="/project/itdd/zhangx2/rapidminer_project/logfiles/log_Lpostive"/> <list key="log"> <parameter key="C" value="operator.SVM.parameter.C"/> <parameter key="gamma" value="operator.SVM.parameter.kernel_gamma"/> <parameter key="performance" value="operator.Performance.value.performance"/> </list> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/>extr <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Free Memory" to_port="through 1"/> <connect from_op="Free Memory" from_port="through 1" to_op="Remap Binominals" to_port="example set input"/> <connect from_op="Remap Binominals" from_port="example set output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_port="result 2"/> <connect from_op="Optimize Parameters (Grid)" from_port="result 1" to_port="result 3"/> <<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="595" width="815"> <operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="75" y="77"> <parameter key="repository_entry" value="../../dataset/10530_213_data"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.2.000" expanded="true" height="94" name="Replace Missing Values" width="90" x="313" y="75"> <list key="columns"/> </operator> <operator activated="true" class="normalize" compatibility="5.2.006" expanded="true" height="94" name="Normalize" width="90" x="45" y="345"/> <operator activated="true" class="free_memory" compatibility="5.2.006" expanded="true" height="76" name="Free Memory" width="90" x="179" y="480"/> <operator activated="true" class="remap_binominals" compatibility="5.2.006" expanded="true" height="76" name="Remap Binominals" width="90" x="380" y="390"> <parameter key="include_special_attributes" value="true"/> <parameter key="negative_value" value="inactive"/> <parameter key="positive_value" value="active"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.2.006" expanded="true" height="112" name="Optimize Parameters (Grid)" width="90" x="715" y="300"> <list key="parameters"> <parameter key="SVM.C" value="5,1"/> </list> <process expanded="true" height="540" width="471"> <operator activated="true" class="x_validation" compatibility="5.2.006" expanded="true" height="112" name="Validation" width="90" x="112" y="120"> <process expanded="true" height="558" width="219"> <operator activated="true" class="support_vector_machine" compatibility="5.2.006" expanded="true" height="112" name="SVM" width="90" x="45" y="30"> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="0.0010"/> <parameter key="C" value="1"/> <parameter key="convergence_epsilon" value="0.0010"/> <parameter key="L_neg" value="5000.0"/> <parameter key="balance_cost" value="true"/> </operator> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="701" width="279"> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="179" y="435"> <parameter key="main_criterion" value="sensitivity"/> <parameter key="accuracy" value="false"/> <parameter key="sensitivity" value="true"/> <parameter key="specificity" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.2.006" expanded="true" height="76" name="Log" width="90" x="313" y="255"> <parameter key="filename" value="/project/itdd/zhangx2/rapidminer_project/logfiles/log_Lpostive"/> <list key="log"> <parameter key="C" value="operator.SVM.parameter.C"/> <parameter key="gamma" value="operator.SVM.parameter.kernel_gamma"/> <parameter key="performance" value="operator.Performance.value.performance"/> </list> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Free Memory" to_port="through 1"/> <connect from_op="Free Memory" from_port="through 1" to_op="Remap Binominals" to_port="example set input"/> <connect from_op="Remap Binominals" from_port="example set output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_port="result 2"/> <connect from_op="Optimize Parameters (Grid)" from_port="result 1" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="595" width="815"> <operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="75" y="77"> <parameter key="repository_entry" value="../../dataset/10530_213_data"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.2.000" expanded="true" height="94" name="Replace Missing Values" width="90" x="313" y="75"> <list key="columns"/> </operator> <operator activated="true" class="normalize" compatibility="5.2.006" expanded="true" height="94" name="Normalize" width="90" x="45" y="345"/> <operator activated="true" class="free_memory" compatibility="5.2.006" expanded="true" height="76" name="Free Memory" width="90" x="179" y="480"/> <operator activated="true" class="remap_binominals" compatibility="5.2.006" expanded="true" height="76" name="Remap Binominals" width="90" x="380" y="390"> <parameter key="include_special_attributes" value="true"/> <parameter key="negative_value" value="inactive"/> <parameter key="positive_value" value="active"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.2.006" expanded="true" height="112" name="Optimize Parameters (Grid)" width="90" x="715" y="300"> <list key="parameters"> <parameter key="SVM.C" value="5,1"/> </list> <process expanded="true" height="540" width="471"> <operator activated="true" class="x_validation" compatibility="5.2.006" expanded="true" height="112" name="Validation" width="90" x="112" y="120"> <process expanded="true" height="558" width="219"> <operator activated="true" class="support_vector_machine" compatibility="5.2.006" expanded="true" height="112" name="SVM" width="90" x="45" y="30"> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="0.0010"/> <parameter key="C" value="1"/> <parameter key="convergence_epsilon" value="0.0010"/> <parameter key="L_neg" value="5000.0"/> <parameter key="balance_cost" value="true"/> </operator> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="701" width="279"> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="179" y="435"> <parameter key="main_criterion" value="sensitivity"/> <parameter key="accuracy" value="false"/> <parameter key="sensitivity" value="true"/> <parameter key="specificity" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="595" width="815"> <operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="75" y="77"> <parameter key="repository_entry" value="../../dataset/10530_213_dextrata"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.2.000" expanded="true" height="94" name="Replace Missing Values" width="90" x="313" y="75"> <list key="columns"/> </operator> <operator activated="true" class="normalize" compatibility="5.2.006" expanded="true" height="94" name="Normalize" width="90" x="45" y="345"/> <operator activated="true" class="free_memory" compatibility="5.2.006" expanded="true" height="76" name="Free Memory" width="90" x="179" y="480"/> <operator activated="true" class="remap_binominals" compatibility="5.2.006" expanded="true" height="76" name="Remap Binominals" width="90" x="380" y="390"> <parameter key="include_special_attributes" value="true"/> <parameter key="negative_value" value="inactive"/> <parameter key="positive_value" value="active"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.2.006" expanded="true" height="112" name="Optimize Parameters (Grid)" width="90" x="715" y="300"> <list key="parameters"> <parameter key="SVM.C" value="5,1"/> </list> <pr<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="595" width="815"> <operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="75" y="77"> <parameter key="repository_entry" value="../../dataset/10530_213_data"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.2.000" expanded="true" height="94" name="Replace Missing Values" width="90" x="313" y="75"> <list key="columns"/> </operator> <operator activated="true" class="normalize" compatibility="5.2.006" expanded="true" height="94" name="Normalize" width="90" x="45" y="345"/> <operator activated="true" class="free_memory" compatibility="5.2.006" expanded="true" height="76" name="Free Memory" width="90" x="179" y="480"/> <operator activated="true" class="remap_binominals" compatibility="5.2.006" expanded="true" height="76" name="Remap Binominals" width="90" x="380" y="390"> <parameter key="include_special_attributes" value="true"/> <parameter key="negative_value" value="inactive"/> <parameter key="positive_value" value="active"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.2.006" expanded="true" height="112" name="Optimize Parameters (Grid)" width="90" x="715" y="300"> <list key="parameters"> <parameter key="SVM.C" value="5,1"/> </list> <process expanded="true" height="540" width="471"> <operator activated="true" class="x_validation" compatibility="5.2.006" expanded="true" height="112" name="Validation" width="90" x="112" y="120"> <process expanded="true" height="558" width="219"> <operator activated="true" class="support_vector_machine" compatibility="5.2.006" expanded="true" height="112" name="SVM" width="90" x="45" y="30"> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="0.0010"/> <parameter key="C" value="1"/> <parameter key="convergence_epsilon" value="0.0010"/> <parameter key="L_neg" value="5000.0"/> <parameter key="balance_cost" value="true"/> </operator> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="701" width="279"> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="179" y="435"> <parameter key="main_criterion" value="sensitivity"/> <parameter key="accuracy" value="false"/> <parameter key="sensitivity" value="true"/> <parameter key="specificity" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.2.006" expanded="true" height="76" name="Log" width="90" x="313" y="255"> <parameter key="filename" value="/project/itdd/zhangx2/rapidminer_project/logfiles/log_Lpostive"/> <list key="log"> <parameter key="C" value="operator.SVM.parameter.C"/> <parameter key="gamma" value="operator.SVM.parameter.kernel_gamma"/> <parameter key="performance" value="operator.Performance.value.performance"/> </list> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Free Memory" to_port="through 1"/> <connect from_op="Free Memory" from_port="through 1" to_op="Remap Binominals" to_port="example set input"/> <connect from_op="Remap Binominals" from_port="example set output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_port="result 2"/> <connect from_op="Optimize Parameters (Grid)" from_port="result 1" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>ocess expanded="true" height="540" width="471"> <operator activated="true" class="x_validation" compatibility="5.2.006" expanded="true" height="112" name="Validation" width="90" x="112" y="120"> <process expanded="true" height="558" width="219"> <operator activated="true" class="support_vector_machine" compatibility="5.2.006" expanded="true" height="112" name="SVM" width="90" x="45" y="30"> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="0.0010"/> <parameter key="C" value="5"/> <parameter key="convergence_epsilon" value="0.0010"/> <parameter key="L_neg" value="5000.0"/> <parameter key="balance_cost" value="true"/> </operator> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="558" width="232"> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="45" y="210"> <parameter key="main_criterion" value="sensitivity"/> <parameter key="accuracy" value="false"/> <parameter key="sensitivity" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.2.006" expanded="true" height="76" name="Log" width="90" x="313" y="255"> <parameter key="filename" value="/project/itdd/zhangx2/rapidminer_project/logfiles/log_Lpostive"/> <list key="log"> <parameter key="C" value="operator.SVM.parameter.C"/> <parameter key="gamma" value="operator.SVM.parameter.kernel_gamma"/> <parameter key="performance" value="operator.Performance.value.performance"/> </list> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Free Memory" to_port="through 1"/> <connect from_op="Free Memory" from_port="through 1" to_op="Remap Binominals" to_port="example set input"/> <connect from_op="Remap Binominals" from_port="example set output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_port="result 2"/> <connect from_op="Optimize Parameters (Grid)" from_port="result 1" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
