<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="512" width="770"> <operator activated="true" class="generate_data" compatibility="5.2.006" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="covariance_matrix" compatibility="5.2.006" expanded="true" height="76" name="Covariance Matrix" width="90" x="179" y="30"/> <operator activated="true" class="reporting:generate_report" compatibility="5.2.000" expanded="true" height="76" name="Generate Report" width="90" x="313" y="75"> <parameter key="report_name" value="grzn"/> <parameter key="format" value="Excel"/> <parameter key="excel_output_file" value="C:\Users\mhelf\Desktop\grzn.xls"/> </operator> <operator activated="true" class="reporting:report" compatibility="5.2.000" expanded="true" height="60" name="Report" width="90" x="447" y="75"> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="Numerical Matrix"/> <parameter key="renderer_name" value="Table View"/> <list key="parameters"> <parameter key="min_row" value="1"/> <parameter key="max_row" value="2147483647"/> <parameter key="min_column" value="1"/> <parameter key="max_column" value="2147483647"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Covariance Matrix" to_port="example set"/> <connect from_op="Covariance Matrix" from_port="example set" to_port="result 1"/> <connect from_op="Covariance Matrix" from_port="covariance" to_op="Generate Report" to_port="through 1"/> <connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/> <connect from_op="Report" from_port="reportable out" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
