I’m playing around with a performance work flow just mentioned in the seminar last week
(thank again for this nice seminar).
I drastically reduced this work flow cutting “Loop Parameters” and “X-Validation” so I left
with “Retrieve” and “Decision Tree”. But running this one it never returns within minutes.
BUT if I create this work flow from scratch it finishes in one second and switches to the result
perspective. I attached these two work flows for further investigations.
Thanks in advance,
Frank
[fras-desktop] Sandbox > cat WF_NotWorks
<process version="5.2.006">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" breakpoints="after" class="process" compatibility="5.2.006" expanded="true" name="Process">
<process expanded="true" height="550" width="752">
<operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75">
<parameter key="repository_entry" value="//Samples/data/Sonar"/>
<operator activated="true" class="decision_tree" compatibility="5.2.006" expanded="true" height="76" name="Decision Tree" width="90" x="313" y="75">
<parameter key="criterion" value="gain_ratio"/>
<parameter key="minimal_size_for_split" value="4"/>
<parameter key="minimal_leaf_size" value="2"/>
<parameter key="minimal_gain" value="0.1"/>
<parameter key="maximal_depth" value="20"/>
<parameter key="confidence" value="0.25"/>
<parameter key="number_of_prepruning_alternatives" value="3"/>
<parameter key="no_pre_pruning" value="false"/>
<parameter key="no_pruning" value="false"/>
<connect from_op="Retrieve" from_port="output" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Decision Tree" from_port="model" to_port="result 1"/>
</process>
</process>
[fras-desktop] Sandbox > cat WF_works
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process">
<process expanded="true" height="397" width="749">
<operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="28" y="66">
<operator activated="true" class="decision_tree" compatibility="5.2.006" expanded="true" height="76" name="Decision Tree" width="90" x="246" y="165">
<connect from_op="Decision Tree" from_port="exampleSet" to_port="result 2"/>
</process>
</process>
