<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="206" width="748"> <operator activated="true" class="generate_sales_data" compatibility="5.2.006" expanded="true" height="60" name="Generate Sales Data" width="90" x="112" y="120"> <parameter key="number_examples" value="100000"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.006" expanded="true" height="76" name="Select Attributes" width="90" x="246" y="120"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|single_price|date|amount"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="date_to_nominal" compatibility="5.2.006" expanded="true" height="76" name="Date to Nominal" width="90" x="380" y="120"> <description>Sun Apr 01 09:09:06 BST 2007</description> <parameter key="attribute_name" value="date"/> <parameter key="date_format" value="yyyyMMdd"/> </operator> <operator activated="true" class="aggregate" compatibility="5.2.006" expanded="true" height="76" name="Aggregate" width="90" x="514" y="120"> <list key="aggregation_attributes"> <parameter key="single_price" value="average"/> <parameter key="amount" value="sum"/> <parameter key="single_price" value="count"/> </list> <parameter key="group_by_attributes" value="|date"/> <parameter key="count_all_combinations" value="true"/> <parameter key="ignore_missings" value="false"/> </operator> <operator activated="true" class="sort" compatibility="5.2.006" expanded="true" height="76" name="Sort" width="90" x="688" y="118"> <parameter key="attribute_name" value="date"/> </operator> <connect from_op="Generate Sales Data" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Date to Nominal" to_port="example set input"/> <connect from_op="Date to Nominal" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
