Would it be possible to install RapidAnalytics server on any remote 'console-only' host?
Once the installer is run it gives the following error:
RapidAnalytics-CE-Installer-1.2.006> java -jar RapidAnalytics-CE-Installer-1.2.006.jar
Exception in thread "main" java.awt.HeadlessException:
No X11 DISPLAY variable was set, but this program performed an operation which requires it.
at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:159)
at java.awt.Window.<init>(Window.java:432)
at java.awt.Frame.<init>(Frame.java:403)
at java.awt.Frame.<init>(Frame.java:368)
at javax.swing.JFrame.<init>(JFrame.java:158)
at com.rapidanalytics.installer.gui.MainFrame.<init>(Unknown Source)
at com.rapidanalytics.installer.gui.MainFrame.init(Unknown Source)
at com.rapidanalytics.installer.Starter.main(Unknown Source)
Thanks,
