<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.007" expanded="true" name="Process"> <process expanded="true" height="555" width="746"> <operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document" width="90" x="112" y="30"> <parameter key="text" value="Hey this is an exmaple"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document (2)" width="90" x="112" y="120"> <parameter key="text" value="Hey this is an exmaple1"/> </operator> <operator activated="true" class="text:documents_to_data" compatibility="5.2.001" expanded="true" height="94" name="Documents to Data (2)" width="90" x="313" y="30"> <parameter key="text_attribute" value="text"/> </operator> <operator activated="true" class="transpose" compatibility="5.2.007" expanded="true" height="76" name="Transpose" width="90" x="447" y="30"/> <operator activated="true" class="generate_attributes" compatibility="5.2.007" expanded="true" height="76" name="Generate Attributes" width="90" x="581" y="30"> <list key="function_descriptions"> <parameter key="changed" value="att_1 != att_2"/> </list> </operator> <connect from_op="Create Document" from_port="output" to_op="Documents to Data (2)" to_port="documents 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Documents to Data (2)" to_port="documents 2"/> <connect from_op="Documents to Data (2)" from_port="example set" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
