Based on video
http://vancouverdata.blogspot.in/2011/10/rapidminer-text-mining-r-analytics.html , I have built below model
<process version="5.2.006">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process">
<parameter key="resultfile" value="C:\Users\Rojas\Desktop\perfekt für clustering\Daten_Reuters_Excell\test.res"/>
<process expanded="true" height="566" width="748">
<operator activated="false" class="text:process_document_from_file" compatibility="5.2.003" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30">
<list key="text_directories">
<parameter key="Service" value="C:\Users\guagg\Desktop\All\RapidMiner\Service"/>
<parameter key="Food" value="C:\Users\guagg\Desktop\All\RapidMiner\food"/>
<parameter key="Waiter" value="C:\Users\guagg\Desktop\All\RapidMiner\Waiter"/>
</list>
<parameter key="file_pattern" value="*.*"/>
<parameter key="extract_text_only" value="false"/>
<parameter key="prune_method" value="percentual"/>
<parameter key="prunde_below_percent" value="5.0"/>
<parameter key="prune_above_percent" value="100.0"/>
<parameter key="prune_below_absolute" value="5"/>
<parameter key="prune_above_absolute" value="100"/>
<parameter key="parallelize_vector_creation" value="true"/>
<process expanded="true" height="383" width="748">
<operator activated="false" class="text:transform_cases" compatibility="5.2.003" expanded="true" height="60" name="Transform Cases" width="90" x="41" y="110"/>
<operator activated="false" class="text:tokenize" compatibility="5.2.003" expanded="true" height="60" name="Tokenize" width="90" x="179" y="120"/>
<operator activated="false" class="text:filter_stopwords_english" compatibility="5.2.003" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="380" y="120"/>
<operator activated="false" class="text:stem_porter" compatibility="5.2.003" expanded="true" height="60" name="Stem (Porter)" width="90" x="514" y="120"/>
<operator activated="false" class="text:generate_n_grams_terms" compatibility="5.2.003" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="648" y="210">
<parameter key="max_length" value="1"/>
<connect from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Stem (Porter)" to_port="document"/>
<connect from_op="Stem (Porter)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
<connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/>
</process>
<operator activated="false" class="store" compatibility="5.2.006" expanded="true" height="60" name="Store" width="90" x="246" y="75">
<parameter key="repository_entry" value="wordlist"/>
<operator activated="false" class="x_validation" compatibility="5.2.006" expanded="true" height="112" name="Validation" width="90" x="380" y="30">
<parameter key="number_of_validations" value="3"/>
<parameter key="parallelize_training" value="true"/>
<parameter key="parallelize_testing" value="true"/>
<process expanded="true" height="383" width="343">
<operator activated="false" class="support_vector_machine_libsvm" compatibility="5.2.006" expanded="true" height="76" name="SVM" width="90" x="112" y="75">
<list key="class_weights"/>
<connect from_port="training" to_op="SVM" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_port="model"/>
<connect from_op="SVM" from_port="exampleSet" to_port="through 1"/>
<portSpacing port="source_training" spacing="0"/>
<portSpacing port="sink_through 2" spacing="0"/>
</process>
<operator activated="false" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="69" y="49">
<parameter key="create_view" value="true"/>
<operator activated="false" class="performance" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="207" y="44"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="through 1" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="source_through 2" spacing="0"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="false" class="store" compatibility="5.2.006" expanded="true" height="60" name="Store (2)" width="90" x="514" y="30">
<parameter key="repository_entry" value="model"/>
<operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Get Wordlist" width="90" x="45" y="300">
<parameter key="repository_entry" value="//NewLocalRepository/wordlist"/>
<operator activated="true" breakpoints="before" class="text:process_document_from_file" compatibility="5.2.003" expanded="true" height="76" name="Process Documents from Files (2)" width="90" x="179" y="300">
<list key="text_directories"/>
<parameter key="use_file_extension_as_type" value="false"/>
<parameter key="keep_text" value="true"/>
<process expanded="true" height="585" width="815">
<operator activated="true" class="text:transform_cases" compatibility="5.2.003" expanded="true" height="60" name="Transform Cases (2)" width="90" x="45" y="165"/>
<operator activated="true" class="text:tokenize" compatibility="5.2.003" expanded="true" height="60" name="Tokenize (2)" width="90" x="179" y="165"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.003" expanded="true" height="60" name="Filter Stopwords (2)" width="90" x="313" y="165"/>
<operator activated="true" class="text:stem_porter" compatibility="5.2.003" expanded="true" height="60" name="Stem (2)" width="90" x="447" y="165"/>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="5.2.003" expanded="true" height="60" name="Generate n-Grams (2)" width="90" x="581" y="165">
<connect from_port="document" to_op="Transform Cases (2)" to_port="document"/>
<connect from_op="Transform Cases (2)" from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
<connect from_op="Filter Stopwords (2)" from_port="document" to_op="Stem (2)" to_port="document"/>
<connect from_op="Stem (2)" from_port="document" to_op="Generate n-Grams (2)" to_port="document"/>
<connect from_op="Generate n-Grams (2)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Get Model" width="90" x="313" y="210">
<parameter key="repository_entry" value="//NewLocalRepository/model"/>
<operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model (3)" width="90" x="514" y="255">
<connect from_op="Process Documents from Files" from_port="example set" to_op="Validation" to_port="training"/>
<connect from_op="Process Documents from Files" from_port="word list" to_op="Store" to_port="input"/>
<connect from_op="Validation" from_port="model" to_op="Store (2)" to_port="input"/>
<connect from_op="Get Wordlist" from_port="output" to_op="Process Documents from Files (2)" to_port="word list"/>
<connect from_op="Process Documents from Files (2)" from_port="example set" to_op="Apply Model (3)" to_port="unlabelled data"/>
<connect from_op="Get Model" from_port="output" to_op="Apply Model (3)" to_port="model"/>
<connect from_op="Apply Model (3)" from_port="labelled data" to_port="result 1"/>
<portSpacing port="sink_result 1" spacing="144"/>
</process>
</process>
But it is not working. Can someone suggest?
Regards
Gunjan
