<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.007" expanded="true" name="Process"> <process expanded="true" height="558" width="634"> <operator activated="true" class="generate_nominal_data" compatibility="5.2.007" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="number_examples" value="1000"/> <parameter key="number_of_attributes" value="1"/> <parameter key="number_of_values" value="50"/> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.2.007" expanded="true" height="76" name="Nominal to Text" width="90" x="179" y="30"/> <operator activated="true" class="text:process_document_from_data" compatibility="5.2.001" expanded="true" height="76" name="Process Documents from Data" width="90" x="380" y="30"> <list key="specify_weights"/> <process expanded="true" height="576" width="806"> <connect from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:wordlist_to_data" compatibility="5.2.001" expanded="true" height="76" name="WordList to Data" width="90" x="514" y="30"/> <operator activated="true" class="sort" compatibility="5.2.007" expanded="true" height="76" name="Sort" width="90" x="112" y="210"> <parameter key="attribute_name" value="total"/> <parameter key="sorting_direction" value="decreasing"/> </operator> <operator activated="true" class="filter_example_range" compatibility="5.2.007" expanded="true" height="76" name="Filter Example Range" width="90" x="246" y="210"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="10"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="word list" to_op="WordList to Data" to_port="word list"/> <connect from_op="WordList to Data" from_port="example set" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="162"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
