<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="read_csv" compatibility="5.2.006" expanded="true" height="60" name="Read CSV" width="90" x="45" y="75"> <parameter key="csv_file" value="C:\Users\Qodmanan\Desktop\test.csv"/> <parameter key="column_separators" value=","/> <parameter key="trim_lines" value="false"/> <parameter key="use_quotes" value="true"/> <parameter key="quotes_character" value="""/> <parameter key="escape_character_for_quotes" value="\"/> <parameter key="skip_comments" value="false"/> <parameter key="comment_characters" value="#"/> <parameter key="parse_numbers" value="true"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="date_format" value=""/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="att1.true.integer.attribute"/> <parameter key="1" value="att2.true.integer.attribute"/> <parameter key="2" value="att3.true.integer.attribute"/> <parameter key="3" value="att4.true.polynominal.label"/> </list> <parameter key="read_not_matching_values_as_missings" value="true"/> <parameter key="datamanagement" value="short_array"/> </operator></process><?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="write_csv" compatibility="5.2.006" expanded="true" height="76" name="Write CSV" width="90" x="581" y="75"> <parameter key="csv_file" value="C:\train\TruncatedData\StratifiedSampledData_0.1Ratio\sampled4.csv"/> <parameter key="column_separator" value=","/> <parameter key="write_attribute_names" value="false"/> <parameter key="quote_nominal_values" value="false"/> <parameter key="format_date_attributes" value="false"/> <parameter key="encoding" value="SYSTEM"/> </operator></process><?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="write_file" compatibility="5.2.006" expanded="true" height="60" name="Write File" width="90" x="715" y="120"> <parameter key="resource_type" value="file"/> <parameter key="filename" value="C:\Users\Qodmanan\Desktop\testtttt.csv"/> <parameter key="mime_type" value="application/octet-stream"/> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="424" width="705"> <operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="sample_stratified" compatibility="5.2.006" expanded="true" height="76" name="Sample (Stratified)" width="90" x="180" y="30"> <parameter key="sample" value="relative"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="2222"/> </operator> <operator activated="true" class="remove_useless_attributes" compatibility="5.2.006" expanded="true" height="76" name="Remove Useless Attributes" width="90" x="315" y="30"/> <operator activated="true" class="format_numbers" compatibility="5.2.006" expanded="true" height="76" name="Format Numbers" width="90" x="450" y="30"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="value_type" value="real"/> <parameter key="include_special_attributes" value="true"/> <parameter key="format_type" value="integer"/> </operator> <operator activated="true" class="write_csv" compatibility="5.2.006" expanded="true" height="76" name="Write CSV" width="90" x="585" y="30"> <parameter key="csv_file" value="C:\train\TruncatedData\StratifiedSampledData_0.1Ratio\sampled4.csv"/> <parameter key="column_separator" value=","/> <parameter key="write_attribute_names" value="false"/> <parameter key="quote_nominal_values" value="false"/> <parameter key="format_date_attributes" value="false"/> </operator> <operator activated="true" class="write_file" compatibility="5.2.006" expanded="true" height="60" name="Write File" width="90" x="581" y="165"> <parameter key="filename" value="C:\train\TruncatedData\sample5"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Sample (Stratified)" to_port="example set input"/> <connect from_op="Sample (Stratified)" from_port="example set output" to_op="Remove Useless Attributes" to_port="example set input"/> <connect from_op="Remove Useless Attributes" from_port="example set output" to_op="Format Numbers" to_port="example set input"/> <connect from_op="Format Numbers" from_port="example set output" to_op="Write CSV" to_port="input"/> <connect from_op="Write CSV" from_port="file" to_op="Write File" to_port="file"/> <connect from_op="Write File" from_port="file" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.007" expanded="true" name="Process"> <process expanded="true" height="424" width="705"> <operator activated="true" class="retrieve" compatibility="5.2.007" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="sample_stratified" compatibility="5.2.007" expanded="true" height="76" name="Sample (Stratified)" width="90" x="180" y="30"> <parameter key="sample" value="relative"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="2222"/> </operator> <operator activated="true" class="remove_useless_attributes" compatibility="5.2.007" expanded="true" height="76" name="Remove Useless Attributes" width="90" x="315" y="30"/> <operator activated="true" class="format_numbers" compatibility="5.2.007" expanded="true" height="76" name="Format Numbers" width="90" x="450" y="30"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="value_type" value="real"/> <parameter key="include_special_attributes" value="true"/> <parameter key="format_type" value="integer"/> </operator> <operator activated="true" class="numerical_to_polynominal" compatibility="5.2.007" expanded="true" height="76" name="Numerical to Polynominal" width="90" x="447" y="165"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="value_type" value="integer"/> </operator> <operator activated="true" class="write_csv" compatibility="5.2.007" expanded="true" height="76" name="Write CSV" width="90" x="581" y="30"> <parameter key="csv_file" value="C:\train\TruncatedData\StratifiedSampledData_0.1Ratio\sampled4.csv"/> <parameter key="column_separator" value=","/> <parameter key="write_attribute_names" value="false"/> <parameter key="quote_nominal_values" value="false"/> <parameter key="format_date_attributes" value="false"/> </operator> <operator activated="true" class="write_file" compatibility="5.2.007" expanded="true" height="60" name="Write File" width="90" x="581" y="165"> <parameter key="filename" value="C:\Users\nwoehler\Desktop\sample5"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Sample (Stratified)" to_port="example set input"/> <connect from_op="Sample (Stratified)" from_port="example set output" to_op="Remove Useless Attributes" to_port="example set input"/> <connect from_op="Remove Useless Attributes" from_port="example set output" to_op="Format Numbers" to_port="example set input"/> <connect from_op="Format Numbers" from_port="example set output" to_op="Numerical to Polynominal" to_port="example set input"/> <connect from_op="Numerical to Polynominal" from_port="example set output" to_op="Write CSV" to_port="input"/> <connect from_op="Write CSV" from_port="file" to_op="Write File" to_port="file"/> <connect from_op="Write File" from_port="file" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
