<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.007" expanded="true" name="Process"> <process expanded="true" height="206" width="614"> <operator activated="true" class="text:read_document" compatibility="5.2.003" expanded="true" height="60" name="Read Document" width="90" x="175" y="113"/> <operator activated="true" class="text:tokenize" compatibility="5.2.003" expanded="true" height="60" name="Tokenize" width="90" x="335" y="110"/> <operator activated="true" class="text:write_document" compatibility="5.2.003" expanded="true" height="76" name="Write Document" width="90" x="514" y="120"/> <connect from_op="Read Document" from_port="output" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="document" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
