<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="670" width="727"> <operator activated="true" class="generate_sales_data" compatibility="5.2.006" expanded="true" height="60" name="Generate Sales Data" width="90" x="45" y="30"/> <operator activated="true" class="select_attributes" compatibility="5.2.006" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|amount|store_id|date"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="multiply" compatibility="5.2.006" expanded="true" height="112" name="Multiply" width="90" x="313" y="30"/> <operator activated="true" class="aggregate" compatibility="5.2.006" expanded="true" height="76" name="Aggregate (2)" width="90" x="447" y="210"> <list key="aggregation_attributes"> <parameter key="amount" value="sum"/> </list> <parameter key="group_by_attributes" value="|date"/> </operator> <operator activated="true" class="sort" compatibility="5.2.006" expanded="true" height="76" name="Sort" width="90" x="581" y="210"> <parameter key="attribute_name" value="sum(amount)"/> </operator> <operator activated="true" class="aggregate" compatibility="5.2.006" expanded="true" height="76" name="Aggregate" width="90" x="447" y="75"> <list key="aggregation_attributes"> <parameter key="amount" value="sum"/> </list> <parameter key="group_by_attributes" value="|store_id"/> </operator> <connect from_op="Generate Sales Data" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_port="result 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Aggregate" to_port="example set input"/> <connect from_op="Multiply" from_port="output 3" to_op="Aggregate (2)" to_port="example set input"/> <connect from_op="Aggregate (2)" from_port="example set output" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_port="result 3"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
