<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE properties SYSTEM "http://java.sun.com/dtd/properties.dtd"><properties><entry key="db_url">yourDBHostname</entry><entry key="db_port">3306</entry><entry key="server_service_id_overwrite">null</entry><entry key="server_port">8080</entry><entry key="db_password">yourDBPassword</entry><entry key="mail_password"/><entry key="installation_directory">C:\Users\yourDesiredRADirectory</entry><entry key="server_host">yourHostname</entry><entry key="server_register_as_service">false</entry><entry key="db_driverclass">com.mysql.jdbc.Driver</entry><entry key="mail_port">25</entry><entry key="server_service_linux_variant">SUSE</entry><entry key="mail_sender"/><entry key="memory_max">1024</entry><entry key="db_system">MySQL</entry><entry key="mail_url"/><entry key="server_service_name">RapidAnalytics Server</entry><entry key="java_home">C:\pathToYourJavaFolder</entry><entry key="db_user">yourDBUser</entry><entry key="server_service_id">RA12SVC</entry><entry key="server_host_bind_only">false</entry><entry key="mail_user"/><entry key="db_schema">yourDBScheme</entry><entry key="db_driver_path">C:\pathToYourJDBCDriverJarForExample\mysql-connector-java-5.1.17-bin.jar</entry></properties>
