Hi All,
I need to append the resultset using different queries where the userID is changing. So first i read a list of userID from a CSV file (this file only has one column, userID). Then I can iterate over the userID using a Loop Value operator. Inside the loop operator I have a readDatabase operator using the following query:
SELECT
"movieID",
genre
FROM movielens10m."Movie"
WHERE "movieID" IN
SELECT
"Rating"."MovieID"
FROM
movielens10m."Rating"
WHERE
"Rating"."userID" = %{loop_value}
Genre is a compound attribute which contains something like value1|value3|value7. After the loop execution, It's sure that output has movieID. But genre maybe has different length of columns for each collection's item. When I try to use the append operator an error is araised because the length of columns is different for each collection's item. I can't use union because this operator does not receive a collection type.
What do you suggest me to do?
Thanks in advance. Below is the flow
<process version="5.2.006">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process">
<process expanded="true" height="235" width="550">
<operator activated="true" class="read_csv" compatibility="5.2.006" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30">
<parameter key="csv_file" value="C:\Users\asistente\Documents\TesisSF\RapidDS\Iterar10m.txt"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations"/>
<parameter key="encoding" value="windows-1252"/>
<parameter key="0" value="userID.true.polynominal.attribute"/>
</list>
<operator activated="true" class="loop_values" compatibility="5.2.006" expanded="true" height="76" name="Loop Values" width="90" x="179" y="30">
<parameter key="attribute" value="userID"/>
<process expanded="true" height="554" width="685">
<operator activated="true" class="read_database" compatibility="5.2.006" expanded="true" height="60" name="MoviesDB (2)" width="90" x="112" y="30">
<parameter key="connection" value="PG_movielens100k"/>
<parameter key="query" value="SELECT "movieID", genre FROM movielens10m."Movie" WHERE "movieID" IN ( SELECT "Rating"."MovieID" FROM movielens10m."Rating" WHERE "Rating"."userID" = %{loop_value} )"/>
<enumeration key="parameters"/>
<operator activated="true" class="set_role" compatibility="5.2.006" expanded="true" height="76" name="movieID_Movies (2)" width="90" x="246" y="30">
<parameter key="name" value="movieID"/>
<operator activated="true" class="replace" compatibility="5.2.006" expanded="true" height="76" name="DashDelete (2)" width="90" x="380" y="30">
<parameter key="attribute" value="genre"/>
<parameter key="replace_what" value="-"/>
<operator activated="true" class="split" compatibility="5.2.006" expanded="true" height="76" name="Genres (2)" width="90" x="514" y="30">
<parameter key="split_pattern" value="\|"/>
<parameter key="split_mode" value="unordered_split"/>
<connect from_op="MoviesDB (2)" from_port="output" to_op="movieID_Movies (2)" to_port="example set input"/>
<connect from_op="movieID_Movies (2)" from_port="example set output" to_op="DashDelete (2)" to_port="example set input"/>
<connect from_op="DashDelete (2)" from_port="example set output" to_op="Genres (2)" to_port="example set input"/>
<connect from_op="Genres (2)" from_port="example set output" to_port="out 1"/>
</process>
<operator activated="true" class="loop_collection" compatibility="5.2.006" expanded="true" height="60" name="Loop Collection" width="90" x="313" y="30">
<operator activated="true" class="recall" compatibility="5.2.006" expanded="true" height="60" name="Recall" width="90" x="45" y="210">
<parameter key="name" value="movies"/>
<parameter key="io_object" value="ExampleSet"/>
<operator activated="true" class="union" compatibility="5.2.006" expanded="true" height="76" name="Union" width="90" x="246" y="30"/>
<operator activated="true" class="remember" compatibility="5.2.006" expanded="true" height="60" name="Remember" width="90" x="447" y="30">
<connect from_port="single" to_op="Union" to_port="example set 1"/>
<connect from_op="Recall" from_port="result" to_op="Union" to_port="example set 2"/>
<connect from_op="Union" from_port="union" to_op="Remember" to_port="store"/>
<portSpacing port="source_single" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
</process>
<operator activated="true" class="recall" compatibility="5.2.006" expanded="true" height="60" name="Recall (2)" width="90" x="450" y="30">
<connect from_op="Read CSV" from_port="output" to_op="Loop Values" to_port="example set"/>
<connect from_op="Loop Values" from_port="out 1" to_op="Loop Collection" to_port="collection"/>
<connect from_op="Recall (2)" from_port="result" to_port="result 1"/>
</process>
</process>
