arty:artierarty:artiest
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.007" expanded="true" name="Process"> <process expanded="true" height="235" width="547"> <operator activated="true" class="text:read_document" compatibility="5.2.001" expanded="true" height="60" name="Read Document" width="90" x="132" y="152"> <parameter key="file" value=""/> </operator> <operator activated="true" class="text:tokenize" compatibility="5.2.001" expanded="true" height="60" name="Tokenize" width="90" x="313" y="165"/> <operator activated="true" class="text:stem_dictionary" compatibility="5.2.001" expanded="true" height="60" name="Stem (Dictionary)" width="90" x="447" y="165"> <parameter key="file" value=""/> </operator> <connect from_op="Read Document" from_port="output" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Stem (Dictionary)" to_port="document"/> <connect from_op="Stem (Dictionary)" from_port="document" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
