jcurry1 wrote:As I understand it, RapidMiner does all of its processing in-memory so the database setup wouldn't affect performance i.e. the data will input into memory through one of the read-in nodes and for all of the procesing from then on, the database is out of the equation. Is it fairly accurate to say this?
