<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.005" expanded="true" name="Process"> <process expanded="true" height="116" width="681"> <operator activated="true" class="generate_nominal_data" compatibility="5.2.005" expanded="true" height="60" name="Generate Nominal Data" width="90" x="112" y="30"> <parameter key="number_of_attributes" value="1"/> </operator> <operator activated="true" class="replace" compatibility="5.2.005" expanded="true" height="76" name="Replace" width="90" x="246" y="30"> <parameter key="replace_what" value="value0"/> <parameter key="replace_by" value="Car Truck Moto"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.005" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="30"> <list key="function_descriptions"> <parameter key="indicator" value="matches(att1, ".*Truck.*")"/> </list> </operator> <operator activated="true" class="filter_examples" compatibility="5.2.005" expanded="true" height="76" name="Filter Examples" width="90" x="514" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="indicator=true"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
tomkowski wrote:Thank you for your answer.I try this operator, but problem is that column B (or A too) value may be one or more word. For example, in column B "Corporation Europe" or "Corp." which is the same for me. I think the best solution will be an operator with regular expression, but I can't find something similar to Filter Examples with regexp. Or maybe I don't know how to write correct expression for Filter Examples operator.
Marius wrote:Heya,a rework of the Filter Examples operator is planned. Until then you have to use a workaround with Generate Attributes: it checks a condition and creates a new indicator attribute, on which you can then apply Filter Examples.Please have a look at the attached process.Best, Marius <?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.005" expanded="true" name="Process"> <process expanded="true" height="116" width="681"> <operator activated="true" class="generate_nominal_data" compatibility="5.2.005" expanded="true" height="60" name="Generate Nominal Data" width="90" x="112" y="30"> <parameter key="number_of_attributes" value="1"/> </operator> <operator activated="true" class="replace" compatibility="5.2.005" expanded="true" height="76" name="Replace" width="90" x="246" y="30"> <parameter key="replace_what" value="value0"/> <parameter key="replace_by" value="Car Truck Moto"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.005" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="30"> <list key="function_descriptions"> <parameter key="indicator" value="matches(att1, ".*Truck.*")"/> </list> </operator> <operator activated="true" class="filter_examples" compatibility="5.2.005" expanded="true" height="76" name="Filter Examples" width="90" x="514" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="indicator=true"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
