<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="296" width="748"> <operator activated="true" class="read_csv" compatibility="5.2.003" expanded="true" height="60" name="Read CSV" width="90" x="112" y="30"> <parameter key="csv_file" value="C:\Users\mhelf\Desktop\test.txt"/> <parameter key="column_separators" value=",\s*|;\s*|\s+|\t+"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="name.true.polynominal.attribute"/> <parameter key="1" value="date.true.polynominal.attribute"/> <parameter key="2" value="contact.true.integer.attribute"/> </list> </operator> <operator activated="true" class="pivot" compatibility="5.2.003" expanded="true" height="76" name="Pivot (2)" width="90" x="246" y="30"> <parameter key="group_attribute" value="name"/> <parameter key="index_attribute" value="contact"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.2.003" expanded="true" height="94" name="Replace Missing Values" width="90" x="380" y="30"> <parameter key="default" value="value"/> <list key="columns"/> <parameter key="replenishment_value" value="X"/> </operator> <operator activated="true" class="k_means" compatibility="5.2.003" expanded="true" height="76" name="Clustering" width="90" x="514" y="30"> <parameter key="measure_types" value="MixedMeasures"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Pivot (2)" to_port="example set input"/> <connect from_op="Pivot (2)" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="clustered set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
