I have the similar question. I followed the links provided, but it is more in a theoritical form. Is there any operator in Rapidminer to select the optimum clusters based on parameters such as entropy, BIC, AIC etc.
Thanks in advance
hi @phani9779 - have you tried just using Auto Model? It will optimize your cluster performance very nicely.
Hi Mr. Scott,
Thanks for your kind reply. Is it possible to conduct SVC clustering in Automodel?
from @IngoRM:
"In theory [SVC clustering] sounds good since it can handle non-linear separations better. In practice, this does not matter that much in large number of dimensions though. It is also terribly slow and hard to tune. Not a big fan myself. So it should come as no surprise that AM is not doing this."
Scott
Hi Scott,
My thanks for your kindness. I am slowly realizing that SVC sounds better in theory but not in practice.
I have some issue with the license activation. Can you please get through this? I have a educational license valid till september, 2019. But after installing the license key, the activation wizard showing the trial duration.
Hi @phani9779,
Don't worry about the license. The license system always takes the license with the most privileges, which is in this case the Trial license (it corresponds to a Large license). When the trial expires it will default back to your educational license.
Best wishes and happy mining
Fabian
Thank you :smileyhappy:
