<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="179" width="480"> <operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data" width="90" x="40" y="53"/> <operator activated="true" class="discretize_by_bins" compatibility="5.2.003" expanded="true" height="94" name="Discretize" width="90" x="183" y="51"> <parameter key="range_name_type" value="short"/> </operator> <operator activated="true" class="nominal_to_binominal" compatibility="5.2.003" expanded="true" height="94" name="Nominal to Binominal" width="90" x="313" y="75"/> <operator activated="true" class="generate_attributes" compatibility="5.2.003" expanded="true" height="76" name="Generate Attributes" width="90" x="490" y="73"> <list key="function_descriptions"> <parameter key="nu" value="if(att5=="range1",true,false)"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
