<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.017"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process"> <process expanded="true" height="386" width="949"> <operator activated="true" class="retrieve" compatibility="5.1.017" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//DB/black.pg/Example Sets/public.vw___w_stats_b_0610"/> </operator> <operator activated="true" class="set_role" compatibility="5.1.017" expanded="true" height="76" name="Set Role" width="90" x="179" y="30"> <parameter key="name" value="hvwo"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.017" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="hvwo|a_at_strength_10|a_at_strength_4|a_at_strength_40|a_de_strength_10|a_de_strength_4|a_de_strength_40|h_at_strength_10|h_at_strength_4|h_at_strength_40|h_de_strength_10|h_de_strength_4|h_de_strength_40||avg_h_score_40|avg_h_score_4|avg_h_score_10|avg_h_concd_40|avg_h_concd_4|avg_h_concd_10|avg_a_score_40|avg_a_score_4|avg_a_score_10|avg_a_concd_40|avg_a_concd_4|avg_a_concd_10"/> </operator> <operator activated="true" class="normalize" compatibility="5.1.017" expanded="true" height="94" name="Normalize" width="90" x="447" y="30"> <parameter key="method" value="range transformation"/> </operator> <operator activated="true" class="neural_net" compatibility="5.1.017" expanded="true" height="76" name="Neural Net" width="90" x="581" y="30"> <list key="hidden_layers"/> <parameter key="normalize" value="false"/> </operator> <operator activated="true" class="retrieve" compatibility="5.1.017" expanded="true" height="60" name="Retrieve (2)" width="90" x="45" y="300"> <parameter key="repository_entry" value="//DB/black.pg/Example Sets/public.vw___w_stats_b_1011"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.017" expanded="true" height="76" name="Select Attributes (2)" width="90" x="179" y="255"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="avg_a_concd_10|avg_a_concd_4|avg_a_concd_40|avg_a_score_10|avg_a_score_4|avg_a_score_40|avg_h_concd_10|avg_h_concd_4|avg_h_concd_40|avg_h_score_10|avg_h_score_4|avg_h_score_40|a_at_strength_10|a_at_strength_4|a_at_strength_40|a_de_strength_10|a_de_strength_4|a_de_strength_40|h_at_strength_10|h_at_strength_4|h_at_strength_40|h_de_strength_10|h_de_strength_4|h_de_strength_40|hvwo"/> </operator> <operator activated="true" class="set_role" compatibility="5.1.017" expanded="true" height="76" name="Set Role (2)" width="90" x="313" y="210"> <parameter key="name" value="hvwo"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"> <parameter key="hvwo" value="label"/> </list> </operator> <operator activated="true" class="apply_model" compatibility="5.1.017" expanded="true" height="76" name="Apply Model (2)" width="90" x="451" y="187"> <list key="application_parameters"/> </operator> <operator activated="true" class="apply_model" compatibility="5.1.017" expanded="true" height="76" name="Apply Model" width="90" x="581" y="165"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.1.017" expanded="true" height="76" name="Performance" width="90" x="715" y="300"/> <connect from_op="Retrieve" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Neural Net" to_port="training set"/> <connect from_op="Normalize" from_port="preprocessing model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Neural Net" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="model" to_port="result 4"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Apply Model" from_port="model" to_port="result 3"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <connect from_op="Performance" from_port="example set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="180"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> <portSpacing port="sink_result 5" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.017"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process"> <parameter key="logverbosity" value="all"/> <process expanded="true" height="460" width="688"> <operator activated="true" class="retrieve" compatibility="5.1.017" expanded="true" height="60" name="Retrieve" width="90" x="112" y="30"> <parameter key="repository_entry" value="../../Models/h_with_ad_as"/> </operator> <operator activated="true" class="retrieve" compatibility="5.1.017" expanded="true" height="60" name="Retrieve (2)" width="90" x="112" y="120"> <parameter key="repository_entry" value="../../Models/norm_h_with_ad_as"/> </operator> <operator activated="true" class="open_file" compatibility="5.1.017" expanded="true" height="60" name="Open File" width="90" x="45" y="255"> <parameter key="filename" value="C:\Users\ml1\Desktop\testdata.csv"/> </operator> <operator activated="true" class="read_csv" compatibility="5.1.017" expanded="true" height="60" name="Read CSV" width="90" x="112" y="345"> <parameter key="csv_file" value="C:\Users\ml1n\Desktop\testdata.csv"/> <parameter key="column_separators" value=","/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="avg_h_score_4.true.real.attribute"/> <parameter key="1" value="avg_h_score_10.true.real.attribute"/> <parameter key="2" value="avg_h_score_40.true.real.attribute"/> <parameter key="3" value="avg_h_concd_4.true.real.attribute"/> <parameter key="4" value="avg_h_concd_10.true.real.attribute"/> <parameter key="5" value="avg_h_concd_40.true.real.attribute"/> <parameter key="6" value="avg_a_score_4.true.real.attribute"/> <parameter key="7" value="avg_a_score_10.true.real.attribute"/> <parameter key="8" value="avg_a_score_40.true.real.attribute"/> <parameter key="9" value="avg_a_concd_4.true.real.attribute"/> <parameter key="10" value="avg_a_concd_10.true.real.attribute"/> <parameter key="11" value="avg_a_concd_40.true.real.attribute"/> <parameter key="12" value="h_at_strength_4.true.real.attribute"/> <parameter key="13" value="h_at_strength_10.true.real.attribute"/> <parameter key="14" value="h_at_strength_40.true.real.attribute"/> <parameter key="15" value="h_de_strength_4.true.real.attribute"/> <parameter key="16" value="h_de_strength_10.true.real.attribute"/> <parameter key="17" value="h_de_strength_40.true.real.attribute"/> <parameter key="18" value="a_at_strength_4.true.real.attribute"/> <parameter key="19" value="a_at_strength_10.true.real.attribute"/> <parameter key="20" value="a_at_strength_40.true.real.attribute"/> <parameter key="21" value="a_de_strength_4.true.real.attribute"/> <parameter key="22" value="a_de_strength_10.true.real.attribute"/> <parameter key="23" value="a_de_strength_40.true.real.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> </operator> <operator activated="true" class="apply_model" compatibility="5.1.017" expanded="true" height="76" name="Apply Model (2)" width="90" x="313" y="210"> <list key="application_parameters"/> </operator> <operator activated="true" class="apply_model" compatibility="5.1.017" expanded="true" height="76" name="Apply Model" width="90" x="514" y="120"> <list key="application_parameters"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Apply Model" to_port="model"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Open File" from_port="file" to_op="Read CSV" to_port="file"/> <connect from_op="Read CSV" from_port="output" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/> <portSpacing port="source_input 1" spacing="108"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.017"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process"> <process expanded="true" height="386" width="949"> <operator activated="true" class="retrieve" compatibility="5.1.017" expanded="true" height="60" name="Retrieve (2)" width="90" x="45" y="255"> <parameter key="repository_entry" value="//football/Latest/data/vwo_1011"/> </operator> <operator activated="true" class="retrieve" compatibility="5.1.017" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//football/Latest/data/vwo_0610"/> </operator> <operator activated="true" class="neural_net" compatibility="5.1.017" expanded="true" height="76" name="Neural Net" width="90" x="581" y="30"> <list key="hidden_layers"/> <parameter key="normalize" value="false"/> </operator> <operator activated="true" class="store" compatibility="5.1.017" expanded="true" height="60" name="Store" width="90" x="715" y="30"> <parameter key="repository_entry" value="home_nn"/> </operator> <operator activated="true" class="apply_model" compatibility="5.1.017" expanded="true" height="76" name="Apply Model" width="90" x="581" y="165"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.1.017" expanded="true" height="76" name="Performance" width="90" x="715" y="300"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Retrieve" from_port="output" to_op="Neural Net" to_port="training set"/> <connect from_op="Neural Net" from_port="model" to_op="Store" to_port="input"/> <connect from_op="Store" from_port="through" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <connect from_op="Performance" from_port="example set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="180"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.017"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process"> <parameter key="logverbosity" value="all"/> <process expanded="true" height="460" width="688"> <operator activated="true" class="retrieve" compatibility="5.1.017" expanded="true" height="60" name="Retrieve" width="90" x="112" y="30"> <parameter key="repository_entry" value="home_nn"/> </operator> <operator activated="true" class="open_file" compatibility="5.1.017" expanded="true" height="60" name="Open File" width="90" x="112" y="165"> <parameter key="filename" value="C:\Users\ml1n\Desktop\testdata.csv"/> </operator> <operator activated="true" class="read_csv" compatibility="5.1.017" expanded="true" height="60" name="Read CSV" width="90" x="112" y="345"> <parameter key="csv_file" value="C:\Users\ml1n\Desktop\testdata.csv"/> <parameter key="column_separators" value=","/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="avg_h_score_4.true.real.attribute"/> <parameter key="1" value="avg_h_score_10.true.real.attribute"/> <parameter key="2" value="avg_h_score_40.true.real.attribute"/> <parameter key="3" value="avg_h_concd_4.true.real.attribute"/> <parameter key="4" value="avg_h_concd_10.true.real.attribute"/> <parameter key="5" value="avg_h_concd_40.true.real.attribute"/> <parameter key="6" value="avg_a_score_4.true.real.attribute"/> <parameter key="7" value="avg_a_score_10.true.real.attribute"/> <parameter key="8" value="avg_a_score_40.true.real.attribute"/> <parameter key="9" value="avg_a_concd_4.true.real.attribute"/> <parameter key="10" value="avg_a_concd_10.true.real.attribute"/> <parameter key="11" value="avg_a_concd_40.true.real.attribute"/> <parameter key="12" value="h_at_strength_4.true.real.attribute"/> <parameter key="13" value="h_at_strength_10.true.real.attribute"/> <parameter key="14" value="h_at_strength_40.true.real.attribute"/> <parameter key="15" value="h_de_strength_4.true.real.attribute"/> <parameter key="16" value="h_de_strength_10.true.real.attribute"/> <parameter key="17" value="h_de_strength_40.true.real.attribute"/> <parameter key="18" value="a_at_strength_4.true.real.attribute"/> <parameter key="19" value="a_at_strength_10.true.real.attribute"/> <parameter key="20" value="a_at_strength_40.true.real.attribute"/> <parameter key="21" value="a_de_strength_4.true.real.attribute"/> <parameter key="22" value="a_de_strength_10.true.real.attribute"/> <parameter key="23" value="a_de_strength_40.true.real.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> </operator> <operator activated="true" class="apply_model" compatibility="5.1.017" expanded="true" height="76" name="Apply Model" width="90" x="514" y="120"> <list key="application_parameters"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Apply Model" to_port="model"/> <connect from_op="Open File" from_port="file" to_op="Read CSV" to_port="file"/> <connect from_op="Read CSV" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/> <portSpacing port="source_input 1" spacing="108"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="245" width="822"> <operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data" width="90" x="38" y="31"/> <operator activated="true" class="normalize" compatibility="5.2.003" expanded="true" height="94" name="Normalize" width="90" x="179" y="30"/> <operator activated="true" class="neural_net" compatibility="5.2.003" expanded="true" height="76" name="Neural Net" width="90" x="320" y="27"> <list key="hidden_layers"/> </operator> <operator activated="true" class="group_models" compatibility="5.2.003" expanded="true" height="94" name="Group Models" width="90" x="514" y="30"/> <operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data (2)" width="90" x="45" y="165"/> <operator activated="true" class="apply_model" compatibility="5.2.003" expanded="true" height="76" name="Apply Model" width="90" x="648" y="120"> <list key="application_parameters"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Neural Net" to_port="training set"/> <connect from_op="Normalize" from_port="preprocessing model" to_op="Group Models" to_port="models in 2"/> <connect from_op="Neural Net" from_port="model" to_op="Group Models" to_port="models in 1"/> <connect from_op="Group Models" from_port="model out" to_op="Apply Model" to_port="model"/> <connect from_op="Generate Data (2)" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/> <connect from_op="Apply Model" from_port="model" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
