<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="482" width="950"> <operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="k_means" compatibility="5.2.003" expanded="true" height="76" name="Clustering" width="90" x="179" y="30"/> <operator activated="true" class="loop_values" compatibility="5.2.003" expanded="true" height="76" name="Loop Values" width="90" x="380" y="30"> <parameter key="attribute" value="cluster"/> <parameter key="iteration_macro" value="cluster"/> <process expanded="true" height="500" width="950"> <operator activated="true" class="filter_examples" compatibility="5.2.003" expanded="true" height="76" name="Filter Examples" width="90" x="45" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="cluster = %{cluster}"/> </operator> <operator activated="true" class="linear_regression" compatibility="5.2.003" expanded="true" height="94" name="Linear Regression (2)" width="90" x="246" y="30"/> <connect from_port="example set" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Linear Regression (2)" to_port="training set"/> <connect from_op="Linear Regression (2)" from_port="model" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="clustered set" to_op="Loop Values" to_port="example set"/> <connect from_op="Loop Values" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
