<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="341" width="480"> <operator activated="true" class="stream_database" compatibility="5.2.003" expanded="true" height="60" name="Stream Database" width="90" x="112" y="165"> <parameter key="connection" value="External"/> <parameter key="table_name" value="user_data_im_monthly_2012_02"/> </operator> <operator activated="true" class="write_csv" compatibility="5.2.003" expanded="true" height="76" name="Write CSV" width="90" x="380" y="165"> <parameter key="csv_file" value="C:\Documents and Settings\GG\My Documents\tttt"/> </operator> <connect from_op="Stream Database" from_port="output" to_op="Write CSV" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
