<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="296" width="480"> <operator activated="true" class="retrieve" compatibility="5.2.003" expanded="true" height="60" name="Retrieve" width="90" x="112" y="75"> <parameter key="repository_entry" value="//Clases/datos/bigeast"/> </operator> <operator activated="true" class="x_validation" compatibility="5.0.000" expanded="true" height="112" name="Validation" width="90" x="313" y="75"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true" height="516" width="232"> <operator activated="true" class="neural_net" compatibility="5.2.003" expanded="true" height="76" name="Neural Net" width="90" x="112" y="75"> <list key="hidden_layers"/> </operator> <connect from_port="training" to_op="Neural Net" to_port="training set"/> <connect from_op="Neural Net" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="516" width="433"> <operator activated="true" class="apply_model" compatibility="5.0.000" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="create_threshold" compatibility="5.2.003" expanded="true" height="60" name="Create Threshold" width="90" x="45" y="210"> <parameter key="first_class" value="Yes"/> <parameter key="second_class" value="No"/> </operator> <operator activated="true" class="apply_threshold" compatibility="5.2.003" expanded="true" height="76" name="Apply Threshold" width="90" x="179" y="210"/> <operator activated="true" class="performance" compatibility="5.0.000" expanded="true" height="76" name="Performance" width="90" x="313" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Apply Threshold" to_port="example set"/> <connect from_op="Create Threshold" from_port="output" to_op="Apply Threshold" to_port="threshold"/> <connect from_op="Apply Threshold" from_port="example set" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
