The file C:\Path\To\Where\The\Files\Were\To\Be\Created\"CategoryName"-"SubCategoryName"-"SubSubCategoryName".csv" does not exist. A file does not exist. For a given filename, RapidMiner resolves the filename against the directory the experiment file is stored in. If there is no experiment file (which is possible in GUI mode for a new, but not saved experiment) the current working directory is used. If the file name denotes an absolute path, the file is not resolved.
%{Category-filter}-%{SubCategory-filter}-%{SubSubCategory-filter}.csv
are you sure that the folder exists and is writable by RapidMiner?
Does your filename contain special characters which might cause problems creating the file?
