I can't acces the Rapidanalytics web interface. I get internal server error 500, with messages:
- javax.servlet.ServletException: Can't find resource for bundle org.ajax4jsf.Messages$EmptyResourceBundle, key ENTER_BEFORE_RENDER_VIEW_PHASE
- java.util.MissingResourceException: Can't find resource for bundle org.ajax4jsf.Messages$EmptyResourceBundle, key ENTER_BEFORE_RENDER_VIEW_PHASE
When I'm executing run.sh I also get an error message:
DEPLOYMENTS IN ERROR:
Deployment "interface javax.transaction.TransactionManager" is in error due to the following reason(s): ** NOT FOUND Depends on 'interface javax.transaction.TransactionManager' **
Deployment "<UNKNOWN ObjectStoreBrowserBean>" is in error due to the following reason(s): ** UNRESOLVED Demands 'TransactionManager' **
Deployment "jboss.jca:service=WorkManager" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss.jca:service=WorkManager' **
Deployment "jboss:service=Naming" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss:service=Naming' **
Deployment "TxControl" is in error due to the following reason(s): java.net.BindException: Address already in use, **ERROR**
Deployment "RemoteNamingBean" is in error due to the following reason(s): java.net.BindException: Address already in use, **ERROR**
Deployment "jboss:service=invoker,type=unified" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss:service=invoker,type=unified' **
Deployment "<UNKNOWN JMSTopicManageMO>" is in error due to the following reason(s): ** UNRESOLVED Demands 'JMSServerManager' **
Deployment "vfs:///home/david/rapidanalytics/server/default/deploy/hsqldb-ds.xml" is in error due to the following reason(s): java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@c27855e5[file =/home/david/rapidanalytics/server/default/data/hypersonic/localDB.lck, exists=true, locked=false, valid=false, fl =null]: java.lang.Exception: checkHeartbeat(): lock file [/home/david/rapidanalytics/server/default/data/hypersonic/localDB.lck] is presumably locked by another process.
Deployment "<UNKNOWN JMSQueueManageMO>" is in error due to the following reason(s): ** UNRESOLVED Demands 'JMSServerManager' **
Deployment "jboss.remoting:service=Connector,transport=socket" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss.remoting:service=Connector,transport=socket' **
Deployment "org.jboss.ejb3.RemotingConnector" is in error due to the following reason(s): java.io.IOException: SocketServerInvoker[ra.minicrm.eu:3873] error creating ServerSocket[0.0.0.0:3873]: Address already in use
Deployment "JMSServerManager" is in error due to the following reason(s): java.net.BindException: Address already in use, **ERROR**
Deployment "XNIO:Binding:-1585199756:RemotingTcpServer" is in error due to the following reason(s): java.net.BindException: Address already in use
Deployment "jboss.jdbc:datasource=DefaultDS,service=metadata" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss.jdbc:datasource=DefaultDS,service=metadata' **
Deployment "<UNKNOWN JMSServerMO>" is in error due to the following reason(s): ** UNRESOLVED Demands 'JMSServerManager' **
Deployment "<UNKNOWN DefaultUserTransactionprovider>" is in error due to the following reason(s): ** UNRESOLVED Demands 'TransactionManager' **
Deployment "jboss:service=TransactionManager" is in error due to the following reason(s): Configured
Deployment "jboss.jca:name=DefaultDS,service=DataSourceBinding" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss.jca:name=DefaultDS,service=DataSourceBinding' **
Deployment "XNIO:Binding:-1585199755:RemotingSslTcpServer" is in error due to the following reason(s): java.net.BindException: Address already in use
Deployment "UnifiedInvokerConnector" is in error due to the following reason(s): **ERROR**, java.io.IOException: SocketServerInvoker[ra.minicrm.eu:4446] error creating ServerSocket[0.0.0.0:4446]: Address already in use
Deployment "<UNKNOWN JMSConnectionFactoryManageMO>" is in error due to the following reason(s): ** UNRESOLVED Demands 'JMSServerManager' **
Deployment "jboss.jca:service=CachedConnectionManager" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss.jca:service=CachedConnectionManager' **
Deployment "jboss:service=WebService" is in error due to the following reason(s): java.net.BindException: Address already in use
Deployment "jboss.web:service=WebServer" is in error due to the following reason(s): Configured
Any idea?
