<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.002" expanded="true" name="Process"> <process expanded="true" height="507" width="983"> <operator activated="true" class="retrieve" compatibility="5.2.002" expanded="true" height="60" name="Retrieve" width="90" x="76" y="24"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.2.002" expanded="true" height="94" name="Optimize Parameters (Grid)" width="90" x="246" y="30"> <list key="parameters"> <parameter key="SVM.C" value="[0.001;1;10;logarithmic]"/> </list> <process expanded="true" height="507" width="983"> <operator activated="true" class="x_validation" compatibility="5.2.002" expanded="true" height="112" name="Validation" width="90" x="112" y="30"> <process expanded="true" height="507" width="466"> <operator activated="true" class="support_vector_machine" compatibility="5.2.002" expanded="true" height="112" name="SVM" width="90" x="112" y="30"> <parameter key="C" value="1.0"/> </operator> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="507" width="466"> <operator activated="true" class="apply_model" compatibility="5.2.002" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.2.002" expanded="true" height="76" name="Performance" width="90" x="246" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.2.002" expanded="true" height="76" name="Log" width="90" x="380" y="30"> <list key="log"> <parameter key="C" value="operator.SVM.parameter.C"/> <parameter key="performance" value="operator.Validation.value.performance"/> <parameter key="stdev" value="operator.Validation.value.deviation"/> </list> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <operator activated="true" breakpoints="after" class="log_to_data" compatibility="5.2.002" expanded="true" height="94" name="Log to Data" width="90" x="447" y="30"> <parameter key="log_name" value="Log"/> </operator> <operator activated="true" class="write_excel" compatibility="5.2.002" expanded="true" height="76" name="Write Excel" width="90" x="648" y="30"> <parameter key="excel_file" value="C:\Users\mhelf\Desktop\test.xls"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_op="Write Excel" to_port="input"/> <connect from_op="Write Excel" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process"> <process expanded="true" height="389" width="701"> <operator activated="true" class="retrieve" compatibility="5.2.001" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//zebra/Results/Attribute Weighting/Chi Squared"/> </operator> <operator activated="true" class="x_validation" compatibility="5.2.001" expanded="true" height="112" name="DT Gain Ratio" width="90" x="179" y="75"> <parameter key="use_local_random_seed" value="true"/> <process expanded="true" height="389" width="263"> <operator activated="true" class="parallel:decision_tree_parallel" compatibility="5.1.000" expanded="true" height="76" name="Decision Tree" width="90" x="86" y="30"> <parameter key="criterion" value="accuracy"/> <parameter key="minimal_gain" value="Infinity"/> <parameter key="number_of_threads" value="2"/> </operator> <connect from_port="training" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="389" width="263"> <operator activated="true" class="apply_model" compatibility="5.2.001" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.2.001" expanded="true" height="76" name="Performance" width="90" x="154" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.2.001" expanded="true" height="76" name="Log" width="90" x="313" y="75"> <list key="log"> <parameter key="Gain ratio" value="operator.DT Gain Ratio.value.performance"/> <parameter key="1" value="operator.DT Gain Ratio.value.performance1"/> <parameter key="f" value="operator.DT Gain Ratio.value.performance2"/> <parameter key="ff" value="operator.DT Gain Ratio.value.performance3"/> <parameter key="ffff" value="operator.DT Gain Ratio.value.performance"/> </list> </operator> <operator activated="true" breakpoints="after" class="log_to_data" compatibility="5.2.001" expanded="true" height="94" name="Log to Data" width="90" x="447" y="30"> <parameter key="log_name" value="Log"/> </operator> <operator activated="true" class="write_excel" compatibility="5.2.001" expanded="true" height="76" name="Write Excel" width="90" x="581" y="30"> <parameter key="excel_file" value="C:\Users\Amir Hossein\Documents\test.xls"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="DT Gain Ratio" to_port="training"/> <connect from_op="DT Gain Ratio" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_op="Write Excel" to_port="input"/> <connect from_op="Write Excel" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
