<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.002" expanded="true" name="Process"> <process expanded="true" height="206" width="882"> <operator activated="true" class="generate_data" compatibility="5.2.002" expanded="true" height="60" name="Generate Data" width="90" x="112" y="30"> <parameter key="target_function" value="random classification"/> </operator> <operator activated="true" class="aggregate" compatibility="5.2.002" expanded="true" height="76" name="Aggregate" width="90" x="246" y="120"> <list key="aggregation_attributes"> <parameter key="att1" value="sum"/> </list> <parameter key="group_by_attributes" value="|label"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.2.002" expanded="true" height="76" name="Filter Examples" width="90" x="380" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="sum(att1) < -5"/> </operator> <operator activated="true" class="rename" compatibility="5.2.002" expanded="true" height="76" name="Rename" width="90" x="514" y="30"> <parameter key="old_name" value="label"/> <parameter key="new_name" value="label2"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="join" compatibility="5.2.002" expanded="true" height="76" name="Join" width="90" x="648" y="120"> <parameter key="join_type" value="left"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="label2" value="label"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.002" expanded="true" height="76" name="Select Attributes" width="90" x="782" y="120"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|sum(att1)|label2"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Aggregate" from_port="original" to_op="Join" to_port="right"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.002" expanded="true" name="Process"> <process expanded="true" height="386" width="1150"> <operator activated="true" class="generate_data" compatibility="5.2.002" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="random classification"/> </operator> <operator activated="true" class="aggregate" compatibility="5.2.002" expanded="true" height="76" name="Aggregate" width="90" x="179" y="30"> <parameter key="use_default_aggregation" value="true"/> <parameter key="default_aggregation_function" value="sum"/> <list key="aggregation_attributes"/> </operator> <operator activated="true" class="transpose" compatibility="5.2.002" expanded="true" height="76" name="Transpose (3)" width="90" x="380" y="165"/> <operator activated="true" class="transpose" compatibility="5.2.002" expanded="true" height="76" name="Transpose" width="90" x="380" y="30"/> <operator activated="true" class="filter_examples" compatibility="5.2.002" expanded="true" height="76" name="Filter Examples" width="90" x="514" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="att_1 > 5"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.002" expanded="true" height="76" name="Select Attributes (2)" width="90" x="648" y="30"> <parameter key="invert_selection" value="true"/> </operator> <operator activated="true" class="replace" compatibility="5.2.002" expanded="true" height="76" name="Replace" width="90" x="782" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="include_special_attributes" value="true"/> <parameter key="replace_what" value="sum\((.*)\)"/> <parameter key="replace_by" value="$1"/> </operator> <operator activated="true" class="join" compatibility="5.2.002" expanded="true" height="76" name="Join" width="90" x="782" y="165"> <parameter key="join_type" value="left"/> <list key="key_attributes"/> </operator> <operator activated="true" class="transpose" compatibility="5.2.002" expanded="true" height="76" name="Transpose (2)" width="90" x="916" y="30"/> <connect from_op="Generate Data" from_port="output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Transpose" to_port="example set input"/> <connect from_op="Aggregate" from_port="original" to_op="Transpose (3)" to_port="example set input"/> <connect from_op="Transpose (3)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Transpose" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_op="Transpose (2)" to_port="example set input"/> <connect from_op="Transpose (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
