siamak_want wrote:Hi,I have downloaded the new version, but it has a new bug:when you run the PaREn, you will see an empty "Error" dialog box with just a close button. And the PaREn does not work at all. If you press the close button, PaREEn will be closed!!!
java.lang.NullPointerException at com.rapidminer.operator.Operator.getParameterAsRepositoryLocation(Operator.java:1396) at com.rapidminer.operator.io.RepositorySource.getRepositoryEntry(RepositorySource.java:91) at com.rapidminer.operator.io.RepositorySource.read(RepositorySource.java:105) at de.dfki.madm.paren.gui.wizard.AutomaticSystemConstructionWizard.readDataSet(AutomaticSystemConstructionWizard.java:94) at de.dfki.madm.paren.gui.wizard.RegressionWizardStep$2.doInBackground(RegressionWizardStep.java:265) at de.dfki.madm.paren.gui.wizard.RegressionWizardStep$2.doInBackground(RegressionWizardStep.java:258) at javax.swing.SwingWorker$1.call(SwingWorker.java:296) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334) at java.util.concurrent.FutureTask.run(FutureTask.java:166) at javax.swing.SwingWorker.run(SwingWorker.java:335) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603) at java.lang.Thread.run(Thread.java:722)
java.lang.NullPointerException at de.dfki.madm.mlwizard.functionality.Regressioner.predict(Regressioner.java:58) at de.dfki.madm.mlwizard.functionality.Regressioner.predict(Regressioner.java:83) at de.dfki.madm.mlwizard.gui.RegressionWizardStep$2.doInBackground(RegressionWizardStep.java:190) at de.dfki.madm.mlwizard.gui.RegressionWizardStep$2.doInBackground(RegressionWizardStep.java:185) at javax.swing.SwingWorker$1.call(Unknown Source) at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source) at java.util.concurrent.FutureTask.run(Unknown Source) at javax.swing.SwingWorker.run(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.lang.Thread.run(Unknown Source)
