<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.017"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process"> <process expanded="true" height="100" width="413"> <operator activated="true" class="retrieve" compatibility="5.1.017" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//AlDi/data/01_mahr_mhrc"/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.1.017" expanded="true" height="60" name="Loop Attributes" width="90" x="246" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|vtang|sigmaN|WzT|WstT|Wear|Rzini|HRC"/> <parameter key="invert_selection" value="true"/> <process expanded="true" height="892" width="1088"> <operator activated="true" class="set_role" compatibility="5.1.017" expanded="true" height="76" name="Set Role" width="90" x="179" y="30"> <parameter key="name" value="%{loop_attribute}"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"> <parameter key="Name" value="id"/> </list> </operator> <operator activated="true" class="retrieve" compatibility="5.1.017" expanded="true" height="60" name="Retrieve (2)" width="90" x="162" y="177"> <parameter key="repository_entry" value="//AlDi/data/01_mahr_mhrc"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.017" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="165"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|HRC|Name|vtang|sigmaN|WzT|WstT|Wear|Rzini"/> </operator> <operator activated="true" class="set_role" compatibility="5.1.017" expanded="true" height="76" name="Set Role (2)" width="90" x="487" y="160"> <parameter key="name" value="Name"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="join" compatibility="5.1.017" expanded="true" height="76" name="Join" width="90" x="715" y="30"> <list key="key_attributes"/> </operator> <connect from_port="example set" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.000" expanded="true" name="Process"> <process expanded="true" height="600" width="614"> <operator activated="true" class="generate_data" compatibility="5.2.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="loop_attributes" compatibility="5.2.000" expanded="true" height="60" name="Loop Attributes" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|att1|att2|att3|att4|att5"/> <parameter key="iteration_macro" value="loop"/> <process expanded="true" height="618" width="614"> <operator activated="true" class="work_on_subset" compatibility="5.2.000" expanded="true" height="76" name="Work on Subset" width="90" x="45" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{loop}"/> <process expanded="true" height="618" width="663"> <operator activated="true" class="set_role" compatibility="5.2.000" expanded="true" height="76" name="Set Role" width="90" x="179" y="30"> <parameter key="name" value="%{loop}"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <connect from_port="exampleSet" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_port="example set"/> <portSpacing port="source_exampleSet" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> </operator> <operator activated="true" class="linear_regression" compatibility="5.2.000" expanded="true" height="94" name="Linear Regression" width="90" x="180" y="30"/> <connect from_port="example set" to_op="Work on Subset" to_port="example set"/> <connect from_op="Work on Subset" from_port="example set" to_op="Linear Regression" to_port="training set"/> <connect from_op="Linear Regression" from_port="exampleSet" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <operator activated="true" class="remember" compatibility="5.2.000" expanded="true" height="60" name="Remember" width="90" x="478" y="35"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="recall" compatibility="5.2.000" expanded="true" height="60" name="Recall" width="90" x="514" y="165"> <parameter key="name" value="model"/> <parameter key="io_object" value="ExampleSet"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_op="Remember" to_port="store"/> <connect from_op="Recall" from_port="result" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Root"> <description></description> <parameter key="random_seed" value="2000"/> <process expanded="true" height="390" width="634"> <operator activated="true" class="retrieve" compatibility="5.2.001" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Polynomial"/> </operator> <operator activated="true" class="generate_id" compatibility="5.2.001" expanded="true" height="76" name="Generate ID" width="90" x="179" y="30"/> <operator activated="true" class="generate_data" compatibility="5.2.001" expanded="true" height="60" name="Generate Data" width="90" x="45" y="300"> <parameter key="number_examples" value="200"/> <parameter key="number_of_attributes" value="50"/> </operator> <operator activated="true" class="generate_id" compatibility="5.2.001" expanded="true" height="76" name="Generate ID (2)" width="90" x="45" y="165"/> <operator activated="true" class="rename_by_replacing" compatibility="5.2.001" expanded="true" height="76" name="Rename by Replacing" width="90" x="179" y="165"> <parameter key="replace_what" value="att"/> <parameter key="replace_by" value="label_"/> </operator> <operator activated="true" class="join" compatibility="5.2.001" expanded="true" height="76" name="Join" width="90" x="313" y="30"> <list key="key_attributes"/> </operator> <operator activated="true" class="set_macro" compatibility="5.2.001" expanded="true" height="76" name="Set Macro" width="90" x="313" y="165"> <parameter key="macro" value="label"/> <parameter key="value" value="label"/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.2.001" expanded="true" height="60" name="Loop Attributes" width="90" x="447" y="165"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="label_.*|att.*"/> <process expanded="true" height="371" width="661"> <operator activated="true" class="exchange_roles" compatibility="5.2.001" expanded="true" height="76" name="Exchange Roles" width="90" x="112" y="30"> <parameter key="first_attribute" value="%{label}"/> <parameter key="second_attribute" value="%{loop_attribute}"/> </operator> <operator activated="true" class="set_macro" compatibility="5.2.001" expanded="true" height="76" name="Set Macro (2)" width="90" x="241" y="27"> <parameter key="macro" value="label"/> <parameter key="value" value="%{loop_attribute}"/> </operator> <operator activated="true" class="work_on_subset" compatibility="5.2.001" expanded="true" height="76" name="Work on Subset" width="90" x="380" y="30"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="%{label}|a.*"/> <parameter key="include_special_attributes" value="true"/> <process expanded="true" height="371" width="661"> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.2.001" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="112" y="30"> <parameter key="macro_name" value="%{label}"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.2.001" expanded="true" height="60" name="Extract Macro" width="90" x="246" y="30"> <parameter key="macro" value="atts"/> <parameter key="macro_type" value="number_of_attributes"/> </operator> <operator activated="true" class="log" compatibility="5.2.001" expanded="true" height="76" name="Log" width="90" x="380" y="30"> <list key="log"> <parameter key="Label" value="operator.Loop Attributes.value.feature_name"/> <parameter key="Atts" value="operator.Extract Macro.value.macro_value"/> </list> </operator> <connect from_port="exampleSet" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="example set"/> <portSpacing port="source_exampleSet" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Exchange Roles" to_port="example set input"/> <connect from_op="Exchange Roles" from_port="example set output" to_op="Set Macro (2)" to_port="through 1"/> <connect from_op="Set Macro (2)" from_port="through 1" to_op="Work on Subset" to_port="example set"/> <connect from_op="Work on Subset" from_port="example set" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <operator activated="true" class="log_to_data" compatibility="5.2.001" expanded="true" height="94" name="Log to Data" width="90" x="514" y="30"/> <connect from_op="Retrieve" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Generate Data" from_port="output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_port="result 1"/> <connect from_op="Log to Data" from_port="through 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Root"> <parameter key="random_seed" value="2000"/> <process expanded="true" height="390" width="634"> <operator activated="true" class="retrieve" compatibility="5.2.001" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Polynomial"/> </operator> <operator activated="true" class="generate_id" compatibility="5.2.001" expanded="true" height="76" name="Generate ID" width="90" x="179" y="30"/> <operator activated="true" class="generate_data" compatibility="5.2.001" expanded="true" height="60" name="Generate Data" width="90" x="45" y="300"> <parameter key="number_examples" value="200"/> <parameter key="number_of_attributes" value="50"/> </operator> <operator activated="true" class="generate_id" compatibility="5.2.001" expanded="true" height="76" name="Generate ID (2)" width="90" x="45" y="165"/> <operator activated="true" class="rename_by_replacing" compatibility="5.2.001" expanded="true" height="76" name="Rename by Replacing" width="90" x="179" y="165"> <parameter key="replace_what" value="att"/> <parameter key="replace_by" value="label_"/> </operator> <operator activated="true" class="join" compatibility="5.2.001" expanded="true" height="76" name="Join" width="90" x="313" y="30"> <list key="key_attributes"/> </operator> <operator activated="true" class="set_macro" compatibility="5.2.001" expanded="true" height="76" name="Set Macro" width="90" x="313" y="165"> <parameter key="macro" value="label"/> <parameter key="value" value="label"/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.2.001" expanded="true" height="60" name="Loop Attributes" width="90" x="447" y="165"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="label_.*|att.*"/> <process expanded="true" height="371" width="661"> <operator activated="true" class="exchange_roles" compatibility="5.2.001" expanded="true" height="76" name="Exchange Roles" width="90" x="112" y="30"> <parameter key="first_attribute" value="%{label}"/> <parameter key="second_attribute" value="%{loop_attribute}"/> </operator> <operator activated="true" class="set_macro" compatibility="5.2.001" expanded="true" height="76" name="Set Macro (2)" width="90" x="241" y="27"> <parameter key="macro" value="label"/> <parameter key="value" value="%{loop_attribute}"/> </operator> <operator activated="true" class="work_on_subset" compatibility="5.2.001" expanded="true" height="76" name="Work on Subset" width="90" x="380" y="30"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="%{label}|a.*"/> <parameter key="include_special_attributes" value="true"/> <process expanded="true" height="371" width="661"> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.2.001" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="112" y="30"> <parameter key="macro_name" value="%{label}"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.2.001" expanded="true" height="60" name="Extract Macro" width="90" x="246" y="30"> <parameter key="macro" value="atts"/> <parameter key="macro_type" value="number_of_attributes"/> </operator> <operator activated="true" breakpoints="before" class="log" compatibility="5.2.001" expanded="true" height="76" name="Log" width="90" x="514" y="75"> <list key="log"> <parameter key="Label" value="operator.Loop Attributes.value.feature_name"/> <parameter key="Atts" value="operator.Extract Macro.value.macro_value"/> </list> </operator> <connect from_port="exampleSet" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="example set"/> <portSpacing port="source_exampleSet" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Exchange Roles" to_port="example set input"/> <connect from_op="Exchange Roles" from_port="example set output" to_op="Set Macro (2)" to_port="through 1"/> <connect from_op="Set Macro (2)" from_port="through 1" to_op="Work on Subset" to_port="example set"/> <connect from_op="Work on Subset" from_port="example set" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <operator activated="true" class="log_to_data" compatibility="5.2.001" expanded="true" height="94" name="Log to Data" width="90" x="514" y="30"/> <connect from_op="Retrieve" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Generate Data" from_port="output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_port="result 1"/> <connect from_op="Log to Data" from_port="through 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
