<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.000" expanded="true" name="Root"> <process expanded="true" height="486" width="299"> <operator activated="true" class="generate_direct_mailing_data" compatibility="5.2.000" expanded="true" height="60" name="DirectMailingExampleSetGenerator" width="90" x="45" y="30"> <parameter key="number_examples" value="10000"/> </operator> <operator activated="true" class="split_validation" compatibility="5.2.000" expanded="true" height="112" name="SimpleValidation" width="90" x="179" y="30"> <process expanded="true" height="626" width="378"> <operator activated="true" class="naive_bayes" compatibility="5.2.000" expanded="true" height="76" name="NaiveBayes" width="90" x="144" y="30"/> <connect from_port="training" to_op="NaiveBayes" to_port="training set"/> <connect from_op="NaiveBayes" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="626" width="378"> <operator activated="true" class="apply_model" compatibility="5.2.000" expanded="true" height="76" name="ModelApplier" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.2.000" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="ModelApplier" to_port="model"/> <connect from_port="test set" to_op="ModelApplier" to_port="unlabelled data"/> <connect from_op="ModelApplier" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="DirectMailingExampleSetGenerator" from_port="output" to_op="SimpleValidation" to_port="training"/> <connect from_op="SimpleValidation" from_port="averagable 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.000" expanded="true" name="Root"> <process expanded="true" height="584" width="962"> <operator activated="true" class="generate_direct_mailing_data" compatibility="5.2.000" expanded="true" height="60" name="DirectMailingExampleSetGenerator" width="90" x="45" y="30"> <parameter key="number_examples" value="10000"/> </operator> <operator activated="true" class="split_validation" compatibility="5.2.000" expanded="true" height="112" name="SimpleValidation" width="90" x="180" y="30"> <process expanded="true" height="626" width="378"> <operator activated="true" class="naive_bayes" compatibility="5.2.000" expanded="true" height="76" name="NaiveBayes" width="90" x="144" y="30"/> <connect from_port="training" to_op="NaiveBayes" to_port="training set"/> <connect from_op="NaiveBayes" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="626" width="378"> <operator activated="true" class="create_lift_chart" compatibility="5.2.000" expanded="true" height="94" name="LiftParetoChart" width="90" x="45" y="30"> <parameter key="target_class" value="response"/> </operator> <operator activated="true" class="remember" compatibility="5.2.000" expanded="true" height="60" name="IOStorer" width="90" x="180" y="30"> <parameter key="name" value="Lift Chart"/> <parameter key="io_object" value="LiftParetoChart"/> </operator> <operator activated="true" class="apply_model" compatibility="5.2.000" expanded="true" height="76" name="ModelApplier" width="90" x="45" y="210"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.2.000" expanded="true" height="76" name="Performance" width="90" x="179" y="210"/> <connect from_port="model" to_op="LiftParetoChart" to_port="model"/> <connect from_port="test set" to_op="LiftParetoChart" to_port="example set"/> <connect from_op="LiftParetoChart" from_port="example set" to_op="ModelApplier" to_port="unlabelled data"/> <connect from_op="LiftParetoChart" from_port="model" to_op="ModelApplier" to_port="model"/> <connect from_op="LiftParetoChart" from_port="lift pareto chart" to_op="IOStorer" to_port="store"/> <connect from_op="ModelApplier" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="recall" compatibility="5.2.000" expanded="true" height="60" name="IORetriever" width="90" x="315" y="30"> <parameter key="name" value="Lift Chart"/> <parameter key="io_object" value="LiftParetoChart"/> </operator> <connect from_op="DirectMailingExampleSetGenerator" from_port="output" to_op="SimpleValidation" to_port="training"/> <connect from_op="SimpleValidation" from_port="averagable 1" to_port="result 2"/> <connect from_op="IORetriever" from_port="result" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
