<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.002" expanded="true" name="Process"> <process expanded="true" height="639" width="757"> <operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document" width="90" x="112" y="30"> <parameter key="text" value="this is a cool test text about testing texts."/> </operator> <operator activated="true" class="text:tokenize" compatibility="5.2.001" expanded="true" height="60" name="Tokenize" width="90" x="234" y="30"/> <operator activated="true" class="text:replace_tokens" compatibility="5.2.001" expanded="true" height="60" name="Replace Tokens" width="90" x="380" y="30"> <list key="replace_dictionary"> <parameter key="^testing$" value="_testing_brand_"/> </list> </operator> <operator activated="true" class="text:stem_porter" compatibility="5.2.001" expanded="true" height="60" name="Stem (Porter)" width="90" x="514" y="30"/> <operator activated="true" class="text:replace_tokens" compatibility="5.2.001" expanded="true" height="60" name="Replace Tokens (2)" width="90" x="648" y="30"> <list key="replace_dictionary"> <parameter key="^_testing_brand_$" value="testing"/> </list> </operator> <connect from_op="Create Document" from_port="output" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Replace Tokens" to_port="document"/> <connect from_op="Replace Tokens" from_port="document" to_op="Stem (Porter)" to_port="document"/> <connect from_op="Stem (Porter)" from_port="document" to_op="Replace Tokens (2)" to_port="document"/> <connect from_op="Replace Tokens (2)" from_port="document" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
