<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process"> <process expanded="true" height="386" width="705"> <operator activated="true" class="read_csv" compatibility="5.2.001" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="csv_file" value="C:\Users\Олег\Desktop\КА НаУКМА\Медіація\Links.csv"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1251"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="text:generate_extract" compatibility="5.2.001" expanded="true" height="60" name="Generate Extract" width="90" x="179" y="30"> <parameter key="source_attribute" value="Links"/> <list key="string_machting_queries"> <parameter key="Links2" value=".&"/> </list> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> </operator> <operator activated="true" class="web:retrieve_webpages" compatibility="5.1.004" expanded="true" height="60" name="Get Pages" width="90" x="45" y="120"> <parameter key="link_attribute" value="Links2"/> <parameter key="page_attribute" value="Page"/> <parameter key="user_agent" value="Opera"/> <parameter key="accept_cookies" value="all"/> </operator> <operator activated="true" class="text:generate_extract" compatibility="5.2.001" expanded="true" height="60" name="Generate Extract (2)" width="90" x="45" y="210"> <parameter key="source_attribute" value="Page"/> <list key="string_machting_queries"> <parameter key="Тривалість" value=""length_seconds": .,"/> <parameter key="Дата" value="<span id="eow-date" class="watch-video-date" >.</span>"/> <parameter key="Опис" value="<p id="eow-description" >.</p>"/> <parameter key="Заголовок" value="<span id="eow-title" class="long-title" dir="ltr" title=".">"/> <parameter key="Likes" value="<span class="likes">.</span>"/> <parameter key="Dislikes" value="<span class="dislikes">.</span>"/> <parameter key="Кількість коментарів" value="<span class="comments-section-stat">(.)</span>"/> <parameter key="Кількість переглядів" value="<span class="watch-view-count"> <strong>.</strong>"/> </list> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> </operator> <operator activated="true" class="replace" compatibility="5.2.001" expanded="true" height="76" name="Replace" width="90" x="179" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Post"/> <parameter key="replace_what" value="<(.*?)>"/> </operator> <operator activated="true" class="replace" compatibility="5.2.001" expanded="true" height="76" name="Replace (2)" width="90" x="313" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Post"/> <parameter key="replace_what" value="&(.*?);"/> <parameter key="replace_by" value=" "/> </operator> <operator activated="true" class="write_csv" compatibility="5.2.001" expanded="true" height="76" name="Write CSV" width="90" x="514" y="75"> <parameter key="csv_file" value="C:\Users\Олег\Desktop\КА НаУКМА\Медіація\Youtube_extract.csv"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Generate Extract" to_port="Example Set"/> <connect from_op="Generate Extract" from_port="Example Set" to_op="Get Pages" to_port="Example Set"/> <connect from_op="Get Pages" from_port="Example Set" to_op="Generate Extract (2)" to_port="Example Set"/> <connect from_op="Generate Extract (2)" from_port="Example Set" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Replace (2)" to_port="example set input"/> <connect from_op="Replace (2)" from_port="example set output" to_op="Write CSV" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process"> <process expanded="true" height="386" width="705"> <operator activated="true" class="read_csv" compatibility="5.2.001" expanded="true" height="60" name="Read CSV" width="90" x="33" y="31"> <parameter key="csv_file" value="C:\Users\Олег\Desktop\КА НаУКМА\Медіація\Links2.csv"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1251"/> <list key="data_set_meta_data_information"> <parameter key="0" value="Links.true.binominal.attribute"/> </list> </operator> <operator activated="true" class="web:retrieve_webpages" compatibility="5.1.004" expanded="true" height="60" name="Get Pages" width="90" x="179" y="30"> <parameter key="link_attribute" value="Links2"/> <parameter key="page_attribute" value="Page"/> <parameter key="user_agent" value="Opera"/> <parameter key="follow_redirects" value="false"/> <parameter key="accept_cookies" value="all"/> </operator> <operator activated="true" class="write_csv" compatibility="5.2.001" expanded="true" height="76" name="Write CSV" width="90" x="313" y="30"> <parameter key="csv_file" value="C:\Users\Олег\Desktop\КА НаУКМА\Медіація\Youtube_extract.csv"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Get Pages" to_port="Example Set"/> <connect from_op="Get Pages" from_port="Example Set" to_op="Write CSV" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process"> <process expanded="true" height="611" width="949"> <operator activated="true" class="read_excel" compatibility="5.2.001" expanded="true" height="60" name="Read Excel" width="90" x="45" y="75"> <parameter key="excel_file" value="E:\Rapidminer\reuters\links_to_check.xls"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="text.true.polynominal.attribute"/> </list> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.2.001" expanded="true" height="76" name="Nominal to Text" width="90" x="179" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="text"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="5.2.001" expanded="true" height="76" name="Process Documents from Data" width="90" x="313" y="75"> <parameter key="add_meta_information" value="false"/> <parameter key="keep_text" value="true"/> <list key="specify_weights"/> <process expanded="true" height="753" width="1094"> <connect from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_examples" compatibility="5.2.001" expanded="true" height="112" name="Loop Examples" width="90" x="447" y="75"> <process expanded="true" height="753" width="681"> <operator activated="true" class="delay" compatibility="5.2.001" expanded="true" height="76" name="Delay" width="90" x="112" y="30"> <parameter key="delay" value="random"/> <parameter key="min_delay_amount" value="500"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.2.001" expanded="true" height="60" name="Extract Macro" width="90" x="315" y="30"> <parameter key="macro" value="website_url"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="text"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="web:get_webpage" compatibility="5.1.004" expanded="true" height="60" name="Get Page" width="90" x="112" y="165"> <parameter key="url" value="%{website_url}"/> <parameter key="random_user_agent" value="true"/> <parameter key="accept_cookies" value="all"/> <list key="query_parameters"/> </operator> <operator activated="true" class="text:write_document" compatibility="5.2.001" expanded="true" height="60" name="Write Document" width="90" x="313" y="165"> <parameter key="file" value="E:\Rapidminer\reuters\pages_to_process\%{example}.html"/> </operator> <connect from_port="example set" to_op="Delay" to_port="through 1"/> <connect from_op="Delay" from_port="through 1" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_port="example set"/> <connect from_op="Get Page" from_port="output" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="document" to_port="output 2"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="18"/> <portSpacing port="sink_output 1" spacing="18"/> <portSpacing port="sink_output 2" spacing="0"/> <portSpacing port="sink_output 3" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="5.2.001" expanded="true" height="76" name="Append" width="90" x="648" y="75"/> <connect from_op="Read Excel" from_port="output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
scepxko wrote:Take a look at the code below and transform it for your own purposesIt reads the "links_to_check.xls" which contains the raw URL list to saveThen saves each page in HTML in a directory for further use.Maybe isn't the coding very elegant but it works for what i needed. Some parts of the code were taken here and there.AlexPS : I just started to learn RapidMiner coding 2 days ago. Ask Nils for complicated questions :-)______________________________________________________ <?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process"> <process expanded="true" height="611" width="949"> <operator activated="true" class="read_excel" compatibility="5.2.001" expanded="true" height="60" name="Read Excel" width="90" x="45" y="75"> <parameter key="excel_file" value="E:\Rapidminer\reuters\links_to_check.xls"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="text.true.polynominal.attribute"/> </list> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.2.001" expanded="true" height="76" name="Nominal to Text" width="90" x="179" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="text"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="5.2.001" expanded="true" height="76" name="Process Documents from Data" width="90" x="313" y="75"> <parameter key="add_meta_information" value="false"/> <parameter key="keep_text" value="true"/> <list key="specify_weights"/> <process expanded="true" height="753" width="1094"> <connect from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_examples" compatibility="5.2.001" expanded="true" height="112" name="Loop Examples" width="90" x="447" y="75"> <process expanded="true" height="753" width="681"> <operator activated="true" class="delay" compatibility="5.2.001" expanded="true" height="76" name="Delay" width="90" x="112" y="30"> <parameter key="delay" value="random"/> <parameter key="min_delay_amount" value="500"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.2.001" expanded="true" height="60" name="Extract Macro" width="90" x="315" y="30"> <parameter key="macro" value="website_url"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="text"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="web:get_webpage" compatibility="5.1.004" expanded="true" height="60" name="Get Page" width="90" x="112" y="165"> <parameter key="url" value="%{website_url}"/> <parameter key="random_user_agent" value="true"/> <parameter key="accept_cookies" value="all"/> <list key="query_parameters"/> </operator> <operator activated="true" class="text:write_document" compatibility="5.2.001" expanded="true" height="60" name="Write Document" width="90" x="313" y="165"> <parameter key="file" value="E:\Rapidminer\reuters\pages_to_process\%{example}.html"/> </operator> <connect from_port="example set" to_op="Delay" to_port="through 1"/> <connect from_op="Delay" from_port="through 1" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_port="example set"/> <connect from_op="Get Page" from_port="output" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="document" to_port="output 2"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="18"/> <portSpacing port="sink_output 1" spacing="18"/> <portSpacing port="sink_output 2" spacing="0"/> <portSpacing port="sink_output 3" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="5.2.001" expanded="true" height="76" name="Append" width="90" x="648" y="75"/> <connect from_op="Read Excel" from_port="output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process"> <process expanded="true" height="431" width="710"> <operator activated="true" class="read_csv" compatibility="5.2.001" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="csv_file" value="C:\Users\Олег\Desktop\КА НаУКМА\Медіація\Links.csv"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1251"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="web:retrieve_webpages" compatibility="5.1.004" expanded="true" height="60" name="Get Pages" width="90" x="179" y="30"> <parameter key="link_attribute" value="Links"/> <parameter key="page_attribute" value="Page"/> <parameter key="user_agent" value="Opera"/> <parameter key="accept_cookies" value="all"/> </operator> <operator activated="true" class="text:generate_extract" compatibility="5.2.001" expanded="true" height="60" name="Generate Extract (2)" width="90" x="45" y="210"> <parameter key="source_attribute" value="Page"/> <list key="string_machting_queries"> <parameter key="Тривалість" value=""length_seconds": .,"/> <parameter key="Дата" value="<span id="eow-date" class="watch-video-date" >.</span>"/> <parameter key="Опис" value="<p id="eow-description" >.</p>"/> <parameter key="Заголовок" value="<span id="eow-title" class="long-title" dir="ltr" title=".">"/> <parameter key="Likes" value="<span class="likes">.</span>"/> <parameter key="Dislikes" value="<span class="dislikes">.</span>"/> <parameter key="Кількість коментарів" value="<span class="comments-section-stat">(.)</span>"/> <parameter key="Кількість переглядів" value="span class="watch-view-count">.</strong>"/> </list> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> </operator> <operator activated="true" class="replace" compatibility="5.2.001" expanded="true" height="76" name="Replace" width="90" x="179" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Опис"/> <parameter key="replace_what" value="<(.*?)>"/> </operator> <operator activated="true" class="replace" compatibility="5.2.001" expanded="true" height="76" name="Replace (2)" width="90" x="313" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Кількість переглядів"/> <parameter key="replace_what" value="<(.*?)>"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.001" expanded="true" height="76" name="Select Attributes" width="90" x="380" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Dislikes|Likes|Дата|Заголовок|Кількість коментарів|Кількість переглядів|Опис|Тривалість|"/> </operator> <operator activated="true" class="write_csv" compatibility="5.2.001" expanded="true" height="76" name="Write CSV" width="90" x="514" y="75"> <parameter key="csv_file" value="C:\Users\Олег\Desktop\КА НаУКМА\Медіація\Youtube_extract.csv"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Get Pages" to_port="Example Set"/> <connect from_op="Get Pages" from_port="Example Set" to_op="Generate Extract (2)" to_port="Example Set"/> <connect from_op="Generate Extract (2)" from_port="Example Set" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Replace (2)" to_port="example set input"/> <connect from_op="Replace (2)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Write CSV" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
