<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <description>Reads collections of text from a set of directories, assigning each directory to a class (as specified by parameter text_directories), and transforms them into a TF-IDF or other word vector. Finally, an SVM is applied to model the input texts.</description> <parameter key="send_mail" value="always"/> <process expanded="true" height="377" width="480"> <operator activated="true" class="text:process_document_from_file" compatibility="5.2.003" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30"> <list key="text_directories"> <parameter key="1" value="C:\Users\ahmad.ali\Documents\dossier-rapidminer\testmining\1"/> <parameter key="2" value="C:\Users\ahmad.ali\Documents\dossier-rapidminer\testmining\2"/> <parameter key="3" value="C:\Users\ahmad.ali\Documents\dossier-rapidminer\testmining\3"/> </list> <parameter key="prune_below_rank" value="5.0"/> <parameter key="prune_above_rank" value="5.0"/> <process expanded="true" height="490" width="570"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.2.000" expanded="true" height="60" name="Extract Content" width="90" x="112" y="30"/> <operator activated="true" class="text:tokenize" compatibility="5.2.003" expanded="true" height="60" name="Tokenize" width="90" x="315" y="30"/> <operator activated="true" class="text:generate_n_grams_characters" compatibility="5.2.003" expanded="true" height="60" name="Generate n-Grams (Characters)" width="90" x="450" y="30"/> <connect from_port="document" to_op="Extract Content" to_port="document"/> <connect from_op="Extract Content" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Generate n-Grams (Characters)" to_port="document"/> <connect from_op="Generate n-Grams (Characters)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="x_validation" compatibility="5.1.002" expanded="true" height="112" name="Validation" width="90" x="313" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true" height="654" width="466"> <operator activated="true" class="naive_bayes" compatibility="5.2.006" expanded="true" height="76" name="Naive Bayes" width="90" x="112" y="30"/> <connect from_port="training" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="654" width="466"> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Process Documents from Files" from_port="example set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
ßÊÈ ÓÇáã ÇáÑÍÈí: ÊäØáÞ Çáíæã ÇáÏæÑÉ ÇáÈÑÇãÌíÉ ÇáÌÏíÏÉ ááÊáíÝÒíæä æÇáÇÐÇÚÉ æÈÑäÇãÌ ÇáÔÈÇÈ æÇáÊí ÊÓÊãÑ ØæÇá ÇÔåÑ
I could able to excute the process through its .rmp file. I am gettin below error when I try to run the process
<em class="error">The operator class 'IntentsOperator' is unknown.</em>com.rapidminer.io.process.XMLImporter.attribute_not_found_unknowncom.rapidminer.io.process.XMLImporter.attribute_not_found_unknowncom.rapidminer.io.process.XMLImporter.attribute_not_found_unknowncom.rapidminer.io.process.XMLImporter.attribute_not_found_unknowncom.rapidminer.io.process.XMLImporter.attribute_not_found_unknowncom.rapidminer.io.process.XMLImporter.attribute_not_found_unknowncom.rapidminer.io.process.XMLImporter.attribute_not_found_unknowncom.rapidminer.io.process.XMLImporter.attribute_not_found_unknown<em class="error">The output port <var>intents</var> is unknown at operator <var>intents</var>.</em>-- ADDING MACROS--test : testNo filename given for result file, using stdout for logging results!Process C:\Users\vc126m\Documents\rapidminercommandexecutor\.RapidMiner5\repositories\Local Repository\processes\intents test.rmp startsProcess failed: The dummy operator intents (replacing IntentsOperator) cannot be executed. Here: Process[1] (Process) subprocess 'Main Process' ==> +- intents[1] (dummy)Process not successful341 [Thread-3] INFO org.eclipse.jetty.util.log - Logging initialized @5395ms384 [Thread-3] INFO spark.embeddedserver.jetty.EmbeddedJettyServer - == Spark has ignited ...385 [Thread-3] INFO spark.embeddedserver.jetty.EmbeddedJettyServer - >> Listening on 0.0.0.0:4567387 [Thread-3] INFO org.eclipse.jetty.server.Server - jetty-9.3.6.v20151106421 [Thread-3] INFO org.eclipse.jetty.server.ServerConnector - Started ServerConnector@554404d{HTTP/1.1,[http/1.1]}{0.0.0.0:4567}421 [Thread-3] INFO org.eclipse.jetty.server.Server - Started @5476ms
Process finished with exit code 1
your RM engine does not find the extension with your custom operator "intents". So you need to be sure that this extension is loaded as well.
Best,
Martin
Hello mschmitz, thank you very much for your reply. Would you please explain me in details how can i add that extensions.
Thanks,
venkat
Hello, Could you please help me with how to add the extensions. I am using RM version 5.3.013.
So it sounds like you created your own extension and compiled it? Is it a JAR file? if so, you will have to place it into your /.RapdiMiner/extensions directory and then restart RapidMiner. I'm not sure where that is in v5.3.
Did you use the developer's guide to make the extension? https://docs.rapidminer.com/developers/
I added rapidminer.jar file in ./RM/extensions directory. But still getting the same
May 24, 2017 2:27:20 PM com.rapidminer.io.process.XMLImporter addMessageINFO: <em class="error">The operator class 'entity-extract' is unknown.</em>May 24, 2017 2:27:20 PM com.rapidminer.io.process.XMLImporter parseOperatorINFO: The parameter 'host_name' is unknown for operator 'entity extract' (" dummy ")."May 24, 2017 2:27:20 PM com.rapidminer.io.process.XMLImporter parseOperatorINFO: The parameter 'host_port' is unknown for operator 'entity extract' (" dummy ")."May 24, 2017 2:27:20 PM com.rapidminer.io.process.XMLImporter parseOperatorINFO: The parameter 'path' is unknown for operator 'entity extract' (" dummy ")."May 24, 2017 2:27:20 PM com.rapidminer.io.process.XMLImporter parseOperatorINFO: The parameter 'groupid' is unknown for operator 'entity extract' (" dummy ")."May 24, 2017 2:27:20 PM com.rapidminer.io.process.XMLImporter parseOperatorINFO: The parameter 'libraryname' is unknown for operator 'entity extract' (" dummy ")."May 24, 2017 2:27:20 PM com.rapidminer.io.process.XMLImporter parseOperatorINFO: The parameter 'languagename' is unknown for operator 'entity extract' (" dummy ")."May 24, 2017 2:27:20 PM com.rapidminer.io.process.XMLImporter parseOperatorINFO: The parameter 'Username' is unknown for operator 'entity extract' (" dummy ")."May 24, 2017 2:27:20 PM com.rapidminer.io.process.XMLImporter parseOperatorINFO: The parameter 'password' is unknown for operator 'entity extract' (" dummy ")."May 24, 2017 2:27:20 PM com.rapidminer.io.process.XMLImporter addMessageINFO: <em class="error">The input port <var>write</var> is unknown at operator <var>entity extract</var>.</em>May 24, 2017 2:27:20 PM com.rapidminer.io.process.XMLImporter addMessageINFO: <em class="error">The output port <var>entityextract</var> is unknown at operator <var>entity extract</var>.</em>May 24, 2017 2:27:20 PM CommandLine serverLoopSEVERE: -- ADDING MACROS--May 24, 2017 2:27:20 PM CommandLine serverLoopSEVERE: test : testMay 24, 2017 2:27:20 PM com.rapidminer.tools.WrapperLoggingHandler logINFO: No filename given for result file, using stdout for logging results!May 24, 2017 2:27:20 PM com.rapidminer.Process runINFO: Process C:\Users\vc126m\Documents\rapidminercommandexecutor\.RapidMiner5\repositories\Local Repository\processes\entityextract.rmp startsMay 24, 2017 2:27:20 PM CommandLine serverLoopSEVERE: Process failed: The dummy operator entity extract (replacing entity-extract) cannot be executed. com.rapidminer.operator.UserError: The dummy operator entity extract (replacing entity-extract) cannot be executed. at com.rapidminer.operator.DummyOperator.doWork(DummyOperator.java:88) at com.rapidminer.operator.Operator.execute(Operator.java:867) at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51) at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:711) at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:375) at com.rapidminer.operator.Operator.execute(Operator.java:867) at com.rapidminer.Process.run(Process.java:949) at com.rapidminer.Process.run(Process.java:873) at com.rapidminer.Process.run(Process.java:832) at com.rapidminer.Process.run(Process.java:827) at com.rapidminer.Process.run(Process.java:817) at CommandLine.serverLoop(CommandLine.java:153) at CommandLine.results(CommandLine.java:202) at CommandLine.main(CommandLine.java:220) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at com.intellij.rt.execution.application.AppMain.main(AppMain.java:147)
May 24, 2017 2:27:20 PM CommandLine serverLoopSEVERE: Here: Process[1] (Process) subprocess 'Main Process' +- Read CSV[1] (Read CSV) ==> +- entity extract[1] (dummy)May 24, 2017 2:27:20 PM CommandLine serverLoopSEVERE: Process not successful
I wonder if there's a Studio versioning issue. V5.3 is pretty old, have you tried it with v7.5?
