<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process"> <process expanded="true" height="611" width="748"> <operator activated="true" class="generate_sales_data" compatibility="5.2.001" expanded="true" height="60" name="Generate Sales Data" width="90" x="112" y="210"/> <operator activated="true" breakpoints="after" class="date_to_nominal" compatibility="5.2.001" expanded="true" height="76" name="Date to Nominal" width="90" x="447" y="210"> <parameter key="attribute_name" value="date"/> <parameter key="date_format" value="w"/> <parameter key="locale" value="German"/> <parameter key="keep_old_attribute" value="true"/> </operator> <operator activated="true" class="parse_numbers" compatibility="5.2.001" expanded="true" height="76" name="Parse Numbers" width="90" x="581" y="210"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="date_nominal"/> </operator> <connect from_op="Generate Sales Data" from_port="output" to_op="Date to Nominal" to_port="example set input"/> <connect from_op="Date to Nominal" from_port="example set output" to_op="Parse Numbers" to_port="example set input"/> <connect from_op="Parse Numbers" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process"> <process expanded="true" height="611" width="1283"> <operator activated="true" class="generate_sales_data" compatibility="5.2.001" expanded="true" height="60" name="Generate Sales Data" width="90" x="112" y="210"/> <operator activated="true" class="date_to_nominal" compatibility="5.2.001" expanded="true" height="76" name="Date to Nominal" width="90" x="246" y="210"> <parameter key="attribute_name" value="date"/> <parameter key="date_format" value="w"/> <parameter key="locale" value="German"/> <parameter key="keep_old_attribute" value="true"/> </operator> <operator activated="true" class="parse_numbers" compatibility="5.2.001" expanded="true" height="76" name="Parse Numbers" width="90" x="380" y="210"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="date_nominal"/> </operator> <operator activated="true" class="rename" compatibility="5.2.001" expanded="true" height="76" name="Rename" width="90" x="447" y="390"> <parameter key="old_name" value="date_nominal"/> <parameter key="new_name" value="week"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="date_to_nominal" compatibility="5.2.001" expanded="true" height="76" name="Date to Nominal (2)" width="90" x="648" y="345"> <parameter key="attribute_name" value="date"/> <parameter key="date_format" value="yyyy"/> <parameter key="locale" value="German"/> <parameter key="keep_old_attribute" value="true"/> </operator> <operator activated="true" class="parse_numbers" compatibility="5.2.001" expanded="true" height="76" name="Parse Numbers (2)" width="90" x="782" y="300"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="date_nominal"/> </operator> <operator activated="true" class="rename" compatibility="5.2.001" expanded="true" height="76" name="Rename (2)" width="90" x="983" y="210"> <parameter key="old_name" value="date_nominal"/> <parameter key="new_name" value="year"/> <list key="rename_additional_attributes"/> </operator> <connect from_op="Generate Sales Data" from_port="output" to_op="Date to Nominal" to_port="example set input"/> <connect from_op="Date to Nominal" from_port="example set output" to_op="Parse Numbers" to_port="example set input"/> <connect from_op="Parse Numbers" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Date to Nominal (2)" to_port="example set input"/> <connect from_op="Date to Nominal (2)" from_port="example set output" to_op="Parse Numbers (2)" to_port="example set input"/> <connect from_op="Parse Numbers (2)" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process"> <process expanded="true" height="611" width="1283"> <operator activated="true" breakpoints="after" class="generate_data_user_specification" compatibility="5.2.001" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="210"> <list key="attribute_values"> <parameter key="date" value="date_parse(1325379661000)"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="date_to_nominal" compatibility="5.2.001" expanded="true" height="76" name="Date to Nominal" width="90" x="246" y="210"> <parameter key="attribute_name" value="date"/> <parameter key="date_format" value="w"/> <parameter key="locale" value="German"/> <parameter key="keep_old_attribute" value="true"/> </operator> <operator activated="true" class="parse_numbers" compatibility="5.2.001" expanded="true" height="76" name="Parse Numbers" width="90" x="380" y="210"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="date_nominal"/> </operator> <operator activated="true" class="rename" compatibility="5.2.001" expanded="true" height="76" name="Rename" width="90" x="447" y="390"> <parameter key="old_name" value="date_nominal"/> <parameter key="new_name" value="week"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="date_to_nominal" compatibility="5.2.001" expanded="true" height="76" name="Date to Nominal (2)" width="90" x="648" y="345"> <parameter key="attribute_name" value="date"/> <parameter key="date_format" value="yyyy"/> <parameter key="locale" value="German"/> <parameter key="keep_old_attribute" value="true"/> </operator> <operator activated="true" class="parse_numbers" compatibility="5.2.001" expanded="true" height="76" name="Parse Numbers (2)" width="90" x="782" y="300"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="date_nominal"/> </operator> <operator activated="true" class="rename" compatibility="5.2.001" expanded="true" height="76" name="Rename (2)" width="90" x="983" y="210"> <parameter key="old_name" value="date_nominal"/> <parameter key="new_name" value="year"/> <list key="rename_additional_attributes"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Date to Nominal" to_port="example set input"/> <connect from_op="Date to Nominal" from_port="example set output" to_op="Parse Numbers" to_port="example set input"/> <connect from_op="Parse Numbers" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Date to Nominal (2)" to_port="example set input"/> <connect from_op="Date to Nominal (2)" from_port="example set output" to_op="Parse Numbers (2)" to_port="example set input"/> <connect from_op="Parse Numbers (2)" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Hi Nils,
I'm new to rapidminer studio 8, I'm trying to get the same thing done with the ISO weeknumbering instead of the US format. Can you please give me guidance how to do it in rapidminder studio 8.
Thank you,
Dong
I figured out how to edit the xml file, got it going already
