Using RapidMiner to create networks
ashkan13
I have a huge database of soccer players for a time interval of 10 years. I am wondering if I can use RapidMiner to create a network of the players showing the players who are likely to be in a same team. I can say it is kind of a collaboration network. I really appreciate your kind comments.
haddock
Hi there,
Perhaps you could look at this exercise as 'frequent item' or 'association rules' mining,
http://en.wikipedia.org/wiki/Association_rule_learning
, there is an example ( 1_25 FPGrowth ) in the the samples provided to get you started.
Good luck!
ashkan13
Thanks for the reply. I've already tried association rules but the problem is that the matrix (word vector) which I get is very sparse and therefore it could not result in associations.
I'm wondering if there is a tool in RapidMiner which can get the word vector and then just draw it as a graph.
Nils_Woehler
If you just want to view the graph you can try to use the Transition Graph operator.
Best,
Nils
haddock
I assume that when you refer to the 'word matrix' you a mean the association rules that are the results of the last operator in the example provided. If you don't get enough rules, try setting the minimum support in the FPGowth operatora bit lower.
ashkan13
By transition graph I think I need to give it the source node and the destination and then it draws the edge, am I right? If yes, it's not working in my case because I have a word vector of the relations between my tokens (players) which shows which players are teammates. Any ideas to draw this matrix?
thx,
