I want to generate a report containing the result of a Naïve Bayes operator. Since the number of attributes varied for each process run, I want the automate the report generation for each attribute with a loop operator. The “Loop Attributes” operator however seems not to be able to handle this report generation. There is an error message “Expected ExampleSet but received KernelDistributionModel”.
Can any of the available loop operators handle the KernelDistributionModel?
Is there an alternate approach to implement a report generation for each attribute in the KernelDistributionModel with some kind of loop operation?
Best Regards,
Volker Voß
Example process:
<process version="5.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process">
<process expanded="true" height="541" width="922">
<operator activated="true" class="generate_data" compatibility="5.2.001" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
<operator activated="true" class="generate_attributes" compatibility="5.2.001" expanded="true" height="76" name="Generate Attributes" width="90" x="45" y="120">
<parameter key="label" value="if(label<0.5,"klein","groß")"/>
</list>
<operator activated="true" class="set_role" compatibility="5.2.001" expanded="true" height="76" name="Set Role" width="90" x="45" y="210">
<parameter key="name" value="label"/>
<operator activated="true" class="naive_bayes_kernel" compatibility="5.2.001" expanded="true" height="76" name="Naive Bayes (Kernel)" width="90" x="45" y="300"/>
<operator activated="true" class="multiply" compatibility="5.2.001" expanded="true" height="94" name="Multiply" width="90" x="179" y="30"/>
<operator activated="true" class="reporting:generate_report" compatibility="5.1.000" expanded="true" height="76" name="Generate Report (2)" width="90" x="313" y="120">
<parameter key="report_name" value="Test Report 2"/>
<parameter key="pdf_output_file" value="C:\Test_Report2.pdf"/>
<operator activated="true" class="reporting:add_section" compatibility="5.1.000" expanded="true" height="76" name="Add Section (2)" width="90" x="447" y="120">
<parameter key="report_section_name" value="Naive Bayes"/>
<operator activated="true" class="loop_attributes" compatibility="5.2.001" expanded="true" height="60" name="Does not work Loop Attributes" width="90" x="581" y="120">
<process expanded="true" height="559" width="940">
<operator activated="true" class="reporting:report" compatibility="5.1.000" expanded="true" height="60" name="Report (2)" width="90" x="45" y="30">
<parameter key="report_item_header" value="%{loop_attribute}"/>
<parameter key="specified" value="true"/>
<parameter key="reportable_type" value="Kernel Bayes Model"/>
<parameter key="renderer_name" value="Plot View"/>
<list key="parameters">
<parameter key="attribute_name" value="%{loop_attribute}"/>
<parameter key="range_" value="."/>
<parameter key="rotate_labels" value="false"/>
</list>
<connect from_port="example set" to_op="Report (2)" to_port="reportable in"/>
<connect from_op="Report (2)" from_port="reportable out" to_port="example set"/>
<portSpacing port="sink_example set" spacing="0"/>
</process>
<operator activated="true" class="reporting:generate_report" compatibility="5.1.000" expanded="true" height="76" name="Generate Report" width="90" x="313" y="30">
<parameter key="report_name" value="Test Report"/>
<parameter key="pdf_output_file" value="C:\Test_Report.pdf"/>
<operator activated="true" class="reporting:add_section" compatibility="5.1.000" expanded="true" height="76" name="Add Section" width="90" x="447" y="30">
<operator activated="true" class="reporting:report" compatibility="5.1.000" expanded="true" height="60" name="Working Report" width="90" x="581" y="30">
<parameter key="report_item_header" value="atr1"/>
<parameter key="attribute_name" value="att1"/>
</list>
<parameter key="image_height" value="800"/>
<connect from_op="Generate Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Naive Bayes (Kernel)" to_port="training set"/>
<connect from_op="Naive Bayes (Kernel)" from_port="model" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Generate Report" to_port="through 1"/>
<connect from_op="Multiply" from_port="output 2" to_op="Generate Report (2)" to_port="through 1"/>
<connect from_op="Generate Report (2)" from_port="through 1" to_op="Add Section (2)" to_port="through 1"/>
<connect from_op="Add Section (2)" from_port="through 1" to_op="Does not work Loop Attributes" to_port="example set"/>
<connect from_op="Does not work Loop Attributes" from_port="example set" to_port="result 2"/>
<connect from_op="Generate Report" from_port="through 1" to_op="Add Section" to_port="through 1"/>
<connect from_op="Add Section" from_port="through 1" to_op="Working Report" to_port="reportable in"/>
<connect from_op="Working Report" from_port="reportable out" to_port="result 1"/>
</process>
</process>
[ /code]
