"[SOLVED] Bug: Distinct Values in Advanced Charts"
I think there might be a bug in the new Advanced Charts, more precisely in "Grouping: Distinct Values".
Lets assume I have a dataset of 1000 examples and I want to create a histogram of a certain attribute a1:
- I drag a1 to the "domain" and the "range" dimension
- I select "grouping: distinct values" in the domain dimension
- I select "aggregation: count" in the range dimension
When I now sum up all the count values for the attribute, I get a sum which is by far less than 1000.
Is this a bug, or did I misunderstand "grouping distinct values" ?
If you want, I can either post a process or pictures showing this (or both of course).
Cheers Q-Dog
