<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.000" expanded="true" name="Process"> <process expanded="true" height="145" width="413"> <operator activated="true" class="generate_sales_data" compatibility="5.2.000" expanded="true" height="60" name="Generate Sales Data" width="90" x="112" y="30"/> <operator activated="true" class="aggregate" compatibility="5.2.000" expanded="true" height="76" name="Aggregate" width="90" x="313" y="30"> <list key="aggregation_attributes"> <parameter key="amount" value="sum"/> </list> <parameter key="group_by_attributes" value="|date"/> </operator> <connect from_op="Generate Sales Data" from_port="output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
