<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.002" expanded="true" name="Process"> <process expanded="true" height="431" width="748"> <operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document" width="90" x="45" y="30"> <parameter key="text" value="this is a test text which contains an indicator word."/> </operator> <operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document (2)" width="90" x="45" y="210"> <parameter key="text" value="blabla blubb blubb"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.2.001" expanded="true" height="112" name="Process Documents" width="90" x="179" y="30"> <parameter key="vector_creation" value="Binary Term Occurrences"/> <process expanded="true" height="639" width="757"> <operator activated="true" class="text:tokenize" compatibility="5.2.001" expanded="true" height="60" name="Tokenize" width="90" x="112" y="30"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.002" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="30"> <list key="function_descriptions"> <parameter key="is_in_cat1" value="if(indicator == 1, "yes", "no")"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.002" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="514" y="30"> <list key="function_descriptions"> <parameter key="is_in_cat2" value="if(indicator == 1 && word ==1, "yes", "no")"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.002" expanded="true" height="76" name="Generate Attributes (3)" width="90" x="648" y="30"> <list key="function_descriptions"> <parameter key="is_in_cat3" value="if(blabla == 1, "yes", "no")"/> </list> </operator> <connect from_op="Create Document" from_port="output" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Process Documents" to_port="documents 2"/> <connect from_op="Process Documents" from_port="example set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Generate Attributes (3)" to_port="example set input"/> <connect from_op="Generate Attributes (3)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
