<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process"> <process expanded="true" height="541" width="969"> <operator activated="true" class="generate_data" compatibility="5.2.001" expanded="true" height="60" name="Generate Data" width="90" x="112" y="30"/> <operator activated="true" class="loop_examples" compatibility="5.2.001" expanded="true" height="76" name="Loop Examples" width="90" x="313" y="30"> <process expanded="true" height="541" width="969"> <operator activated="true" class="generate_macro" compatibility="5.2.001" expanded="true" height="76" name="Generate Macro" width="90" x="45" y="30"> <list key="function_descriptions"> <parameter key="ex_minus_1" value="%{example}-1"/> </list> </operator> <operator activated="true" class="handle_exception" compatibility="5.2.001" expanded="true" height="76" name="Handle Exception" width="90" x="313" y="30"> <process expanded="true" height="541" width="459"> <operator activated="true" class="extract_macro" compatibility="5.2.001" expanded="true" height="60" name="Extract Macro" width="90" x="112" y="30"> <parameter key="macro" value="value"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="att1"/> <parameter key="example_index" value="%{ex_minus_1}"/> </operator> <operator activated="true" class="print_to_console" compatibility="5.2.001" expanded="true" height="76" name="Print to Console" width="90" x="313" y="30"> <parameter key="log_value" value="%{value}"/> </operator> <connect from_port="in 1" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Print to Console" to_port="through 1"/> <connect from_op="Print to Console" from_port="through 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <process expanded="true" height="541" width="459"> <connect from_port="in 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Handle Exception" to_port="in 1"/> <connect from_op="Handle Exception" from_port="out 1" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
