<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.017"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process"> <process expanded="true" height="633" width="743"> <operator activated="true" class="generate_data" compatibility="5.1.017" expanded="true" height="60" name="Generate Data" width="90" x="112" y="30"> <parameter key="target_function" value="polynomial classification"/> <parameter key="number_examples" value="1000"/> </operator> <operator activated="true" class="naive_bayes" compatibility="5.1.017" expanded="true" height="76" name="Naive Bayes" width="90" x="246" y="30"/> <operator activated="true" class="generate_data" compatibility="5.1.017" expanded="true" height="60" name="Generate Data (2)" width="90" x="112" y="120"> <parameter key="target_function" value="polynomial classification"/> <parameter key="number_examples" value="3"/> </operator> <operator activated="true" class="apply_model" compatibility="5.1.017" expanded="true" height="76" name="Apply Model" width="90" x="380" y="75"> <list key="application_parameters"/> </operator> <operator activated="true" class="aggregate" compatibility="5.1.017" expanded="true" height="76" name="Aggregate" width="90" x="514" y="30"> <list key="aggregation_attributes"> <parameter key="prediction(label)" value="mode"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Generate Data (2)" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
