<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.017"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process"> <process expanded="true" height="145" width="212"> <operator activated="true" class="loop_repository" compatibility="5.1.017" expanded="true" height="76" name="Loop Repository" width="90" x="45" y="30"> <parameter key="repository_folder" value="//Samples/data/"/> <parameter key="entry_type" value="IOObject"/> <process expanded="true" height="574" width="840"> <operator activated="true" class="extract_macro" compatibility="5.1.017" expanded="true" height="60" name="Extract Macro" width="90" x="45" y="30"> <parameter key="macro" value="size"/> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.1.017" expanded="true" height="76" name="Provide Macro as Log Value (2)" width="90" x="179" y="30"> <parameter key="macro_name" value="repository_path"/> </operator> <operator activated="true" class="log" compatibility="5.1.017" expanded="true" height="76" name="Log" width="90" x="313" y="30"> <list key="log"> <parameter key="Dataset" value="operator.Provide Macro as Log Value (2).value.macro_value"/> <parameter key="Size" value="operator.Extract Macro.value.macro_value"/> </list> </operator> <connect from_port="repository object" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Provide Macro as Log Value (2)" to_port="through 1"/> <connect from_op="Provide Macro as Log Value (2)" from_port="through 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="out 1"/> <portSpacing port="source_repository object" spacing="0"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Loop Repository" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
This process has no errors, although it is a bit weird that you retrieve each dataset twice:
