<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.017"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process"> <process expanded="true" height="637" width="950"> <operator activated="true" class="retrieve" compatibility="5.1.017" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="5.1.017" expanded="true" height="94" name="Nominal to Numerical" width="90" x="182" y="72"> <parameter key="coding_type" value="dummy coding"/> <parameter key="use_comparison_groups" value="true"/> <list key="comparison_groups"> <parameter key="Wind" value="false"/> <parameter key="Outlook" value="sunny"/> </list> </operator> <connect from_op="Retrieve" from_port="output" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
