<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.017"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process"> <process expanded="true" height="145" width="413"> <operator activated="true" class="generate_data_user_specification" compatibility="5.1.017" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30"> <list key="attribute_values"> <parameter key="text" value=""CapitalizedStringIntoSingleWords""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="replace" compatibility="5.1.017" expanded="true" height="76" name="Replace" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="text"/> <parameter key="replace_what" value="([A-Z])"/> <parameter key="replace_by" value=" $1"/> </operator> <operator activated="true" class="trim" compatibility="5.1.017" expanded="true" height="76" name="Trim" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="text"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Trim" to_port="example set input"/> <connect from_op="Trim" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.017"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process"> <process expanded="true" height="145" width="413"> <operator activated="true" class="generate_data_user_specification" compatibility="5.1.017" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30"> <list key="attribute_values"> <parameter key="text" value=""CapitalizedStringIntoSingleWords""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="replace" compatibility="5.1.017" expanded="true" height="76" name="Replace" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="text"/> <parameter key="replace_what" value="((?<!^)[A-Z])"/> <parameter key="replace_by" value=" $1"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.017"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true" height="566" width="882"> <operator activated="true" class="text:create_document" compatibility="5.1.004" expanded="true" height="60" name="Create Document" width="90" x="45" y="30"> <parameter key="text" value="CompanyEarningsAnnouncement"/> <parameter key="add label" value="false"/> <parameter key="label_type" value="nominal"/> </operator> <operator activated="true" class="text:documents_to_data" compatibility="5.1.004" expanded="true" height="76" name="Documents to Data" width="90" x="45" y="120"> <parameter key="text_attribute" value="subClass"/> <parameter key="add_meta_information" value="true"/> <parameter key="datamanagement" value="double_sparse_array"/> </operator> <operator activated="true" class="replace" compatibility="5.1.017" expanded="true" height="76" name="Replace (2)" width="90" x="45" y="210"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value="subClass"/> <parameter key="attributes" value="|subClass|superClass"/> <parameter key="regular_expression" value="#*"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value=".*#"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.1.017" expanded="true" height="76" name="Filter Examples" width="90" x="179" y="210"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="subClass=CompanyEarningsAnnouncement"/> <parameter key="invert_filter" value="false"/> </operator> <operator activated="true" class="replace" compatibility="5.1.017" expanded="true" height="76" name="Replace" width="90" x="179" y="120"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="subClass"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="[A-Z]"/> <parameter key="replace_by" value=" $1"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_op="Replace (2)" to_port="example set input"/> <connect from_op="Replace (2)" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
