I am trying to create a report by using "Generate Report" and then "Report". The format of the report is
excel. I have tried to solve this problem on my own but to no avail.
I have replicated the identical process as shown on this link:
http://www.myexperiment.org/workflows/1279.html. Every time I run the process, in the log i get the following message:
SEVERE: Report: No report specified: skipping reporting operator. Please make all necessary settings in the option dialog."
In the "Generate Report" operator the parameters are:
- report name: Excel
- excel output file: C:\ExcelReport.xls
In the "Report" operator the parameters are:
My Sys Specs. are:
- Win 7 32 bit
- UAC level 0
- Office 2010 (only 2003 format is being used for all excel files -.xls)
- RapidMiner v. 5.1.017
- RapidMiner run mode (always as Admin - just in case because UAC level 0 should take care of this)
Also the output file has a worksheet created with the desired name (Excel in this case). So it is obvious to me that the issue lies with the "Report" operator (also as suggested by the log).
In simple words, I am just trying to get the results of the process into an excel file. Is this a known issue? Is there a workaround? Or am I just not able to see a superbly simple solution?
Thanks in advance for your help.
please find below the xml file....
<process version="5.1.017">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process">
<parameter key="resultfile" value="C:\ExcelReport.xls"/>
<process expanded="true" height="-20" width="-50">
<operator activated="true" class="generate_data" compatibility="5.1.017" expanded="true" height="60" name="Generate Data" width="90" x="78" y="84"/>
<operator activated="true" class="correlation_matrix" compatibility="5.1.017" expanded="true" height="94" name="Correlation Matrix" width="90" x="276" y="82"/>
<operator activated="true" class="reporting:generate_report" compatibility="5.1.000" expanded="true" height="76" name="Generate Report" width="90" x="443" y="83">
<parameter key="report_name" value="Excel"/>
<parameter key="format" value="Excel"/>
<parameter key="excel_output_file" value="C:\ExcelReport.xls"/>
<operator activated="true" class="reporting:report" compatibility="5.1.000" expanded="true" height="60" name="Report" width="90" x="648" y="51">
<list key="parameters"/>
<connect from_op="Generate Data" from_port="output" to_op="Correlation Matrix" to_port="example set"/>
<connect from_op="Correlation Matrix" from_port="example set" to_op="Generate Report" to_port="through 1"/>
<connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/>
<connect from_op="Report" from_port="reportable out" to_port="result 1"/>
</process>
</process>
