DatatoWeights operator[SOLVED]
Chrisirgens
Hi again,
This is really a sort of follow-on from the issue solved by Marius earlier.
The operator DatatoWeights is defined as creating a new attribute weights IOObject from an example set, yet states also that the result is a vector whose elements are simply set to 1. Does this mean that there is no way that a set of weights values can be taken from an ExampleSet and recast as a new weights object? It seems impossible to scale ExampleSet vectors (examples) with any other object type than weight type.
Kindest Regards,
ChrisI
MariusHelf
Hi Chris,
an example set does not contain *attribute* weights. Thus the Data to Weights has no chance to "extract" anything different 1 from the example set. From your post however I am not sure what you are trying to do. If you want to apply weights on the *examples* instead of the attributes, you can create a new attribute with Generate Attribute and assign the role "label" to it with Set Role.
Best,
Marius
Chrisirgens
Hi Marius,
Many thanx again, this has given me some food for thought so I shall use your 'catalyst' to explore. :-)
Kindest Regards,
Chris.
