<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.011"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process"> <process expanded="true" height="633" width="743"> <operator activated="true" class="generate_data" compatibility="5.1.011" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="random classification"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.1.011" expanded="true" height="94" name="Optimize Parameters (Grid)" width="90" x="246" y="30"> <list key="parameters"> <parameter key="Set Macro.value" value="1,2,3"/> <parameter key="Set Macro (2).value" value="1,2,3"/> </list> <process expanded="true" height="633" width="748"> <operator activated="true" class="set_macro" compatibility="5.1.011" expanded="true" height="76" name="Set Macro" width="90" x="112" y="30"> <parameter key="macro" value="w1"/> <parameter key="value" value="3"/> </operator> <operator activated="true" class="set_macro" compatibility="5.1.011" expanded="true" height="76" name="Set Macro (2)" width="90" x="112" y="120"> <parameter key="macro" value="w2"/> <parameter key="value" value="3"/> </operator> <operator activated="true" class="support_vector_machine_libsvm" compatibility="5.1.011" expanded="true" height="76" name="SVM" width="90" x="313" y="30"> <list key="class_weights"> <parameter key="positive" value="%{w1}"/> <parameter key="negative" value="%{w2}"/> </list> </operator> <operator activated="true" class="apply_model" compatibility="5.1.011" expanded="true" height="76" name="Apply Model" width="90" x="447" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.1.011" expanded="true" height="76" name="Performance" width="90" x="581" y="30"/> <connect from_port="input 1" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Set Macro (2)" to_port="through 1"/> <connect from_op="Set Macro (2)" from_port="through 1" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="SVM" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
