<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.017"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process"> <process expanded="true" height="206" width="279"> <operator activated="true" class="text:process_document_from_file" compatibility="5.1.004" expanded="true" height="76" name="Process Documents from Files" width="90" x="112" y="75"> <list key="text_directories"> <parameter key="bills" value="D:\Bills"/> </list> <parameter key="file_pattern" value="112~h1*"/> <parameter key="add_meta_information" value="false"/> <parameter key="keep_text" value="true"/> <parameter key="prune_method" value="absolute"/> <parameter key="prune_below_absolute" value="2"/> <parameter key="prune_above_absolute" value="9999"/> <process expanded="true" height="596" width="970"> <operator activated="true" class="text:tokenize" compatibility="5.1.004" expanded="true" height="60" name="Tokenize" width="90" x="112" y="120"/> <operator activated="true" class="text:transform_cases" compatibility="5.1.004" expanded="true" height="60" name="Transform Cases" width="90" x="541" y="75"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="36"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="data_to_similarity" compatibility="5.1.017" expanded="true" height="76" name="Data to Similarity" width="90" x="263" y="212"> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="DiceSimilarity"/> </operator> <connect from_op="Process Documents from Files" from_port="example set" to_op="Data to Similarity" to_port="example set"/> <connect from_op="Data to Similarity" from_port="similarity" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0"?><VLDocking version="2.1"><DockingDesktop name="default"><DockingPanel><Split orientation="1" location="0.7996044825313118"><Split orientation="1" location="0.24979321753515302"><Split orientation="0" location="0.19928400954653938"><Dockable><Key dockName="overview"/></Dockable><TabbedDockable><Dockable><Key dockName="new_operator"/></Dockable><Dockable><Key dockName="repository_browser"/></Dockable></TabbedDockable></Split><Split orientation="0" location="0.7995226730310262"><TabbedDockable><Dockable><Key dockName="process_panel"/></Dockable><Dockable><Key dockName="xml_editor"/></Dockable></TabbedDockable><TabbedDockable><Dockable><Key dockName="error_table"/></Dockable><Dockable><Key dockName="log_viewer"/></Dockable></TabbedDockable></Split></Split><Split orientation="0" location="0.6599045346062052"><Dockable><Key dockName="property_editor"/></Dockable><TabbedDockable><Dockable><Key dockName="operator_help"/></Dockable><Dockable><Key dockName="comment_editor"/></Dockable></TabbedDockable></Split></Split></DockingPanel><TabGroups><TabGroup><Dockable><Key dockName="new_operator"/></Dockable><Dockable><Key dockName="repository_browser"/></Dockable><Dockable><Key dockName="repository_browser"/></Dockable></TabGroup><TabGroup><Dockable><Key dockName="operator_help"/></Dockable><Dockable><Key dockName="comment_editor"/></Dockable><Dockable><Key dockName="comment_editor"/></Dockable></TabGroup><TabGroup><Dockable><Key dockName="error_table"/></Dockable><Dockable><Key dockName="log_viewer"/></Dockable><Dockable><Key dockName="log_viewer"/></Dockable></TabGroup><TabGroup><Dockable><Key dockName="process_panel"/></Dockable><Dockable><Key dockName="xml_editor"/></Dockable><Dockable><Key dockName="xml_editor"/></Dockable></TabGroup></TabGroups></DockingDesktop></VLDocking>
<?xml version="1.0"?><VLDocking version="2.1"><DockingDesktop name="default"><DockingPanel><Split orientation="1" location="0.7996044825313118"><Split orientation="1" location="0.24979321753515302"><Split orientation="0" location="0.19928400954653938"><Dockable><Key dockName="overview"/></Dockable><TabbedDockable><Dockable><Key dockName="new_operator"/></Dockable><Dockable><Key dockName="repository_browser"/></Dockable></TabbedDockable></Split><Split orientation="0" location="0.7995226730310262"><TabbedDockable><Dockable><Key dockName="process_panel"/></Dockable><Dockable><Key dockName="xml_editor"/></Dockable></TabbedDockable><TabbedDockable><Dockable><Key dockName="error_table"/></Dockable><Dockable><Key dockName="log_viewer"/></Dockable></TabbedDockable></Split></Split><Split orientation="0" location="0.6599045346062052"><Dockable><Key dockName="property_editor"/></Dockable><TabbedDockable><Dockable><Key dockName="operator_help"/></Dockable><Dockable><Key dockName="comment_editor"/></Dockable></TabbedDockable></Split></Split></DockingPanel><TabGroups><TabGroup><Dockable><Key dockName="new_operator"/></Dockable><Dockable><Key dockName="repository_browser"/></Dockable><Dockable><Key dockName="repository_browser"/></Dockable><Dockable><Key dockName="repository_browser"/></Dockable></TabGroup><TabGroup><Dockable><Key dockName="operator_help"/></Dockable><Dockable><Key dockName="comment_editor"/></Dockable><Dockable><Key dockName="comment_editor"/></Dockable><Dockable><Key dockName="comment_editor"/></Dockable></TabGroup><TabGroup><Dockable><Key dockName="error_table"/></Dockable><Dockable><Key dockName="log_viewer"/></Dockable><Dockable><Key dockName="log_viewer"/></Dockable><Dockable><Key dockName="log_viewer"/></Dockable></TabGroup><TabGroup><Dockable><Key dockName="process_panel"/></Dockable><Dockable><Key dockName="xml_editor"/></Dockable><Dockable><Key dockName="xml_editor"/></Dockable><Dockable><Key dockName="xml_editor"/></Dockable></TabGroup></TabGroups></DockingDesktop></VLDocking>
